Drivetrain The best spark plugs for pullied cars?
Old Mar 11, 2008 | 06:11 AM
sprp85's Avatar
sprp85
Ugh.
I searched before and came up with too many posts with too many opinions and I wanted to just clean some things up...
I have 17%, with NGK BKR7EIX - 11 , 1 step colder, i believe..
It has worked flawlessly for last 30k miles or so... no problems YET but I definitely feel that I need to change it just to be safe..
Now, should I go two step colder? (380cc, 17%, intake, exhaust) or just stick with wut I have right now?
Also, do anyone know how much the OEM plug wires are? I figured that it would be better to just change the wires often vs. buying 150 wires that won't do much..
thanks in advance
Old Mar 11, 2008 | 09:26 AM
Jhud's Avatar
Jhud
I second this thread. I have a 15% pulley and a 2% crank and a few other mods. i try to research spark plugs ( as far as hotter and cooler ) and theres literally hundereds of pages of mostly opinions. can someone clear this up for me? i am running factory NGK now and want the best for my application. Nice thread SPRP85.
Old Mar 11, 2008 | 09:49 AM
70spop's Avatar
70spop
Originally Posted by sprp85
Ugh.
thanks in advance
If you've run 30,000 miles and have had no problems with the plugs and are not getting detonation, then why change? It sounds like what you have works fine, so I'd stick with it.
IIRC, the factory wires are about $60 for the set - either the black or the colors.
Old Mar 11, 2008 | 11:06 AM
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
We sell and use the BRISK plugs and have been very happy with them. They use a silver electrode and come in two heat ranges. For a pullied car obviously the colder range is ideal. You can see both on our website!
Let me know if I can help further!
Old Mar 11, 2008 | 11:22 AM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
I put colder plugs in and had to change back to stock because I was running to rich for some reason...I know this does not make sence, but hey not everything does...
I think that you really have to be running your car pretty hard to effectively use the colder plugs, or just need a tune
Old Mar 11, 2008 | 11:43 AM
minimarks's Avatar
minimarks
Denso IK22 has worked great for me....
Old Mar 11, 2008 | 04:09 PM
ignote's Avatar
ignote
Stick with what you have. Just get a new set.
Old Mar 11, 2008 | 05:46 PM
MiniMacPR's Avatar
MiniMacPR
I also put colder plugs (Denso IK22) and they got fouled. I never knew if it was just the plugs, though, since the time with the plugs coincided with a Unichip. I replaced the Densos with the stockers, removed the Unichip, and have had no problems since
Btw, I have 15% pulley/header/catback/intake and JCW flash
Old Mar 11, 2008 | 07:45 PM
minimarks's Avatar
minimarks
No fouling here and no Unichip.
Old Mar 12, 2008 | 05:54 AM
aokdoug's Avatar
aokdoug
denso 22 here. 19% - 380s- giac flash. pulled today:look new. 20K MILES
DOUG
Old Mar 12, 2008 | 07:56 AM
Bahamabart's Avatar
Bahamabart
independent of brand - many here have opted for one step colder plugs.
I swapped out to Denso IK22 - can't say its made any noticeable difference but I have not had any negative issues.
Not a bit investment - if you need plugs worth a try.
09R56
Nov 16, 2022 10:49 AM
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
tr3y003
Oct 22, 2015 10:48 AM
azntaiji
Aug 13, 2015 03:24 PM
tippin
Aug 5, 2015 08:43 AM
