Drivetrain can old belt cause power loss?
Old Mar 7, 2008 | 06:52 PM
blackman's Avatar
blackman
hey i've searched the site but cant seem to find an answer. can an old supercharger belt cause power loss? i have an upgraded 19% pulley with about 20,000 miles on the belt, almost two years on the car. my car doesnt seem as fast as it used to, now i know this happens when you drive the car for a few years, but honestly, i remember the pull it used to have when i first installed it.plus, i'm losing more stoplight races now anybody know?
Old Mar 7, 2008 | 07:01 PM
BlimeyCabrio's Avatar
BlimeyCabrio
Belt could be slipping... that would do it...
Old Mar 7, 2008 | 07:03 PM
herbie hind's Avatar
herbie hind
do a search on belt size etc. you'll find photos of where you want the holes of the metal slider on the tentioner to show . this relates to the amount of stretch . if a hole doesnt show above the tentioner spring you should change the belt .
Old Mar 7, 2008 | 07:15 PM
JAB 67's Avatar
JAB 67
check your engine air filter.
Old Mar 7, 2008 | 07:33 PM
hemiheaded18's Avatar
hemiheaded18
Also check the plugs. With a 19% pulley, they might be out of the proper heat range for that much boost.
Old Mar 7, 2008 | 08:17 PM
blackman's Avatar
blackman
put in new plugs, clean my filter regularly...thanx tho, might jus have to put on a new belt, it cudnt hurt i suppose.....
Old Mar 8, 2008 | 04:39 AM
Bahamabart's Avatar
Bahamabart
Regardless of the pulley and belt size you use these suckers stretch and slip which translates to power loss. You know that there is a gauge on the belt tensioner that will give you an indication but my was slipping even though it indicated that the tension was still good. I basically change belts once a year.
Old Mar 8, 2008 | 09:32 AM
thulchatt's Avatar
thulchatt
Helped a friend to change his belt and he gained 2 lbs of boost with a year old belt. That was with a 15% pulley.
We could not do mine because the tool broke.
While the others have given additional things to look at, changing the belt will likely help.
tylewis
Sep 6, 2015 01:07 PM
Sep 3, 2015 02:06 PM
Ntety
Sep 2, 2015 08:39 PM
Sep 2, 2015 11:15 AM
Suspension Products
Sep 2, 2015 10:32 AM
