Drivetrain obx header high flow cat question
Old Mar 6, 2008 | 01:34 PM
2002redMCS's Avatar
2002redMCS
i am about to purchase the obx header but would like to add a high flow cat to it instead of hacking the stock one off of the stock header...is there one that will easily be attached to the obx header while still having the bung for the sensor? If you know of one a part number/name/place to purchase would be greatly appreciated. thanks in advance.
Old Mar 6, 2008 | 01:38 PM
cycleguru's Avatar
cycleguru
I'll be ordering mine soon from www.helix13.com
Old Mar 6, 2008 | 02:01 PM
UKSUV's Avatar
UKSUV
The best advice is spend some extra money and do V-band flanges . I have an OBX header for sale brand neeeeeew....
Old Mar 6, 2008 | 05:05 PM
norm03s's Avatar
norm03s
Look here;
https://www.northamericanmotoring.co...00&ppuser=6865
works great!
Old Mar 6, 2008 | 05:45 PM
2002redMCS's Avatar
2002redMCS
thanks...
for those looking for a high flow cat that works with the obx header the thing is a Magnaflow high flow cat prt # 94136 its about $70 bucks....
Old Mar 7, 2008 | 05:48 AM
Bahamabart's Avatar
Bahamabart
it just seems to me that most bought a high flow cat because it said high flow and the end diameters matched up. I have raised this several times yet no one can answer this question - can you tell me how you calculated it was high flow over the stocker and how much more flow over the stocker.
Old Mar 7, 2008 | 12:02 PM
2002redMCS's Avatar
2002redMCS
i didnt buy it to be "high flow", i just needed a cat so i didnt have to hack the one off of my stock header off. If its higher flow than the stock cat than thats a plus for me, but higher flow was not my intention for it, but rather a way for me not to mess with the stock cat.....
Old Mar 7, 2008 | 06:44 PM
norm03s's Avatar
norm03s
Well it just seemed to me that it would do the trick and it did,
This comment is there if you scrolled down the link I posted.
If I remember right this is sized for a 3.2L so on a MCS it's got the flow.
2-1/2" In/Out, with a single O2 sensor boss, OBD-II EPA Compliant
Funneled Flow Director On Inlet And Outlet For Maximum Flow
Heavy Gauge Stainless Steel Construction
High-Flow Monolithic Honeycomb Catalyst
Seam Welded Shell.
Old Mar 8, 2008 | 04:51 AM
Bahamabart's Avatar
Bahamabart
Seam Welded Shell.
Its a GOOD and logical assumption that if its good for 3.2L then it will easily accommodate our 1.6L. I am just surprised that here on NAM it has not been defined more - i.e. what the stocker flows, what would be appropriate for a lightly modded car or heavily modded car. Perhaps it doesn't matter.
Old Mar 18, 2008 | 11:49 AM
jtack's Avatar
jtack
Originally Posted by 2002redMCS
thanks...
Does this aftermarket CAT bolt directly onto the OBX Header, or is there any welding to be done with this set up? Also any o2 simulators to deal with?
Old Mar 18, 2008 | 12:30 PM
discodan's Avatar
discodan
Just had the first CAT in my stock manifold blow apart on me Sat. night. just ordered the one from Helix with the high-flow Random Tech. Cat as a replacement. will write in with a full evaluation this weekend when i get it installed. the guys @ Helix said it will bolt right up in place of the stocker so i'm assuming both bungs for the O2 sensors and everything will be there. i'll try and take some pics too, you guys gotta see the CAT !
Old Mar 18, 2008 | 03:14 PM
SharoSC02's Avatar
SharoSC02
Perhaps the professionals will chime in on this but I was told by a good source that almost all after market cats do burn out. The stock cat is actually very well made and it holds pretty good under extreme heat. jm2c.
Old Mar 18, 2008 | 03:24 PM
AstroBlackS's Avatar
AstroBlackS
I've had my obx with random tech. cat from helix, for a while now. No problems as of yet.
Old Mar 18, 2008 | 03:28 PM
UKSUV's Avatar
UKSUV
All cats burn out eventually....some faster than others. Random Technology cats are some of the best made. I would have one if I could afford it.
Old Mar 18, 2008 | 03:31 PM
jtack's Avatar
jtack
when using the obx header with an aftermarket cat, do these pieces bolt up and then bolt to the cat back or is there welding involved?
Old Mar 18, 2008 | 03:42 PM
UKSUV's Avatar
UKSUV
with the pic I just added for the Random Tech cat above...you can either weld flanges on or permanently weld them in place. I would put flanges on myself..
Old Mar 18, 2008 | 03:46 PM
ThumperMCS's Avatar
ThumperMCS
That's what mine looked like! They're not THAT expensive! Especially for someone that is doing a turbo build on a Cooper..... ( I think you still are...)
Old Mar 18, 2008 | 03:49 PM
UKSUV's Avatar
UKSUV
That's if I had a job. I got out of the AF back in Nov...lol. Turbo project on hold for a few months.
Old Mar 18, 2008 | 03:56 PM
ThumperMCS's Avatar
ThumperMCS
Oh shoot man, that sucks!
On a unrelated note, get a bunch of people together and come to BimmerFest with me!
Old Mar 18, 2008 | 03:58 PM
UKSUV's Avatar
UKSUV
Well...Im still figuring out AMVIV..Im not going at the moment. I just got another Sheltie and the money issues... Oh...and what car do I take....the BMW or the Mini....LMAO
Old Mar 19, 2008 | 08:06 AM
Bahamabart's Avatar
Bahamabart
from what I've read and heard these cats are top notch and worth the money.
Old Mar 20, 2008 | 01:13 PM
SharoSC02's Avatar
SharoSC02
Just talked to Ralph at Helix about weather this cat is California legal. He was uncertain of this and I wanted to ask anyone here if they know this particular cat is California smog legal?
Sharo
Old Mar 20, 2008 | 02:01 PM
glnr13's Avatar
glnr13
Sharo
you should give them a call 770-554-4242
Old Mar 20, 2008 | 05:21 PM
UKSUV's Avatar
UKSUV
Sharo
Well I know a ton of BMW guys (sc/turbo and FI) running these in Cali with no smog problems. It just needs an O2 bung welded in at some point.
Jan 4, 2019 12:51 PM
Aug 12, 2015 01:24 PM
Aug 11, 2015 11:58 AM
Aug 10, 2015 02:03 PM
Aug 10, 2015 01:59 PM
