Suspension 18 Inch Rims, Lowered...Crap!
Old Feb 28, 2008 | 09:40 AM
JENNICIDAL13's Avatar
JENNICIDAL13
So, I purchased an 02 Mini Cooper a couple months ago, Love it! Except it has 18 inch rims and is lowered. The lowering springs have gone out in the rear and I think I'm just going to get new springs. The tires are 225/40 18 which I think is too big anyway. Should I just get the springs fixed and then get smaller tires later? The rims are actually quite nice so I'm reluctant to get rid of them.
Old Feb 28, 2008 | 09:46 AM
flingger's Avatar
flingger
It's not the rim size...it's the tire. You need a lower profile tire. Unfortunately, this will create a somewhat fragile situation making potholes your worst enemy.
Old Feb 28, 2008 | 09:57 AM
Minifiend's Avatar
Minifiend
I run 215-35-18 and its not a problem in terms of rubbing. Alot of other people are running this same setup and its not a problem either. In terms of ride quality, its not horrible...but maybe I am just used to it.
Old Feb 28, 2008 | 11:06 AM
pauliekeys's Avatar
pauliekeys
Depending on the size of your rims, you might want to think about going to a 205/40/18 or a 215/40/18. I myself run a 215/35/18 and it's true that you need to watch out for bad road ALL the time. It won't take much to wreck a rim with that size tire. I plan on going to a 215/40/18 next time around. My 18's are a 18X7.5.
Old Feb 28, 2008 | 11:07 AM
jakay11's Avatar
jakay11
Stock Rolling dia. on first gen Minis was 24.26mm (with 17" rims)
Going +1s with these on 18s means that you'd want 225/35s (24.20) or 215/35 (23.93) - speedo reads high
215/40 (24.77) - speedo reads low
Your current 225/40s have a rolling dia or 25.09, so your speedo is reading much slower than you are actually going...
When you say that the lowered springs have gone out, I'm assuming you mean that they broke... so I'd replace them with stock units if you don't mind the higher ride height.
Old Mar 1, 2008 | 06:40 PM
JENNICIDAL13
Thanks everyone!
Mine are 18X7.5 also.
I wasn't sure if the tires would fit right if I put the stock springs on. I think I would rather have the stock setup because I live in pothole heaven, which is why I think the springs are broken in the first place! If the car is going to look ridiculous with the huge rims at stock height I might just take the tires down a size. I don't even know!
Also- I thought the speedometer was off! It's a wonder I haven't been pulled over because I've speeding according to the car already- ha.
Old Mar 3, 2008 | 02:20 PM
succubus's Avatar
succubus
I don't understand. If you raise it to stock height why would you want a smaller tire?
Old Mar 3, 2008 | 03:43 PM
JENNICIDAL13
I don't, if I don't raise it I will get the smaller tires. I think I'm just going to get the stock ones and leave the tires as is.
Old Mar 3, 2008 | 03:53 PM
Longboard Mini's Avatar
Longboard Mini
215 x 40 x 18 Toyo T1R's. They are great! Best combo yet.
Longboard
Old Mar 3, 2008 | 04:22 PM
JENNICIDAL13
Does anyone know where I can find some stock springs? Is that what I search under or is there a part number?
Old Mar 3, 2008 | 05:35 PM
amorican's Avatar
amorican
Just check the marketplace. I sold my stock springs last year when I did my Hsports...I am sure many people have old ones they would be happy to part with.
luisfv56
Nov 16, 2015 01:55 PM
malibujoey
Nov 9, 2015 08:22 PM
Winston46
Nov 9, 2015 06:18 AM
krohm
Sep 28, 2015 12:16 PM
2011minnie
Sep 27, 2015 10:44 AM
