Suspension Koni Adj. Yellow Sports, TSW Springs, and H-Sport Camber Plates Installed
Old Feb 23, 2008 | 02:48 PM
cpayne's Avatar
cpayne
Ok I finished and just got back from a test drive....WOW!!!
The steering is so crisp and reponsive compared to the Stock Sport Suspension and this is on Studded Snow Tires! I think I will have to wear a G-Suit once I get the Summer Rubber on!!
Driving Impressions:
-1) Like I said above very quick steering
-2) Minimal body roll that I can feel
-3) 2 Degree Negative Camber on front
-4) Koni' set to 1/2 from full soft (1 turn stiff) and ride is amazing! In fact I would say it is better then the OEM bouncy ride I noticed and is not harsh at all!
-5) Able to accelerate out of the corners earlier w/o loosing, as much traction
-6) Drop so far is pretty minimal..but will let suspension settle for a few days then measure.
Dislikes:
-1) H-Sport Camber plates seem to be occasionally creaking on slow parking lot manuevers. Also in neighborhood bumpy streets at slow speeds. Not sure "if" there is anythng I can do to help that? Or just a concequence of these plates?
-2) The additonal front negative camber, steering wheel does not want to return to center as quickly/easy coming out of a turn. It almost wants to keep turning if you took your hands off the wheel??
Install Notes:
Fronts:
-1) Passenger side for some reason is harder to get the new strut in to the knuckle on the lower a-arm/hub carrier. Seems the a-arm does not drop down as far as the drivers side did. Had to get creative to compress the spring/assembly to get it to slide in to the a-arm. Using a car jack and breaker bar which Jon Kessel showed me how. Great technique for removing the OEM's too.
-2) Rears you do have to modify 2 holes from the OEM assembly from 10mm to 12mm. A 15/32" drill bit works too as that is 11.9mm (close enough) You have to drill out the upper spring seat to 12mm and the Concave Washer. I did on a drill press and worked great. Just hard to do the washer as it wants to spin..but got it done. The rest of the parts are provided by Koni.
- I was able to do the passenger side w/o a spring compressor just had to have my wife's help. The drivers side we were close but just couldnt compress it that extra 1/8" so took over to local shop and they compressed it for me for free!
All in all a awesome combination!!! Can wait to get the summer rubber (TBD) and SSR Comp wheels on!
If I can figure out the camber plate noise that would be a bonus!!
Old Feb 23, 2008 | 03:15 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Originally Posted by cpayne
-2) The additonal front negative camber steering wheel does not want to return to center as quickly/easy coming out of a turn. It almost wants to keep turning?
After adding camber plates on my car with -2º camber, the steering wheel was more prone to returning to center. I think more camber makes the castor's effect on the return to center more pronounced.
Noise is no longer an issue with my plates. I guess they are broken in or something. It's been 10,000 miles since I had them installed.
Old Feb 23, 2008 | 03:30 PM
cpayne's Avatar
cpayne
Interesting on the returning to center comment. I mean it doesnt feel bad persay. Just different. Just feels like the car is on rails and maybe that isnt a bad thing.
Will report back on that here in a few days.
Regarding noise...you running H-Sport plates?
thx!
Old Feb 23, 2008 | 08:16 PM
cpayne's Avatar
cpayne
Just put a quick spray of WD-40 on the camber plates where the meet the Koni's...quiet for now....interesting
cp
Old Feb 24, 2008 | 12:04 PM
RedSkunk's Avatar
RedSkunk
The less "returning to center" feeling is probably the result of less caster – installing lowering springs decreases the amount of caster. Unfortunate byproduct of looking good.
Old Feb 24, 2008 | 09:53 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
I have IE adjustable plates and stock springs/dampers.
Old Feb 25, 2008 | 06:35 AM
jblow's Avatar
jblow
Just curious, if the Konis are made for the Mini application, why do the rear shock mounts need to be drilled out?
Old Feb 25, 2008 | 08:15 AM
spdfreak's Avatar
spdfreak
It's not the shock mount that is drilled out, it's the upper spring seat that is drilled as the koni's have a larger diameter shaft than stock
Old Feb 25, 2008 | 08:31 AM
cpayne's Avatar
cpayne
Correct
Old Feb 25, 2008 | 01:09 PM
RedSkunk's Avatar
RedSkunk
Muh post was directed to the OP.
Old Feb 25, 2008 | 05:58 PM
03Indigo's Avatar
03Indigo
User Title's are Silly
Old Feb 29, 2008 | 07:52 PM
cpayne's Avatar
cpayne
Gotta give you guys a 1 week update:
Lets just say perfect in my mind...very driveable and flogable on daily basis.
All noise gone! Cant wait for Summer Rubber!
Old Mar 1, 2008 | 09:20 AM
nabeshin's Avatar
nabeshin
Functioning Lunatic
I know that, I was just reafirming that with stock ride height return to center is improved with camber plates and generous neg camber.
W0TM8
Dec 19, 2019 07:50 AM
Emnotek
Aug 13, 2015 05:47 PM
Minibeagle
Aug 13, 2015 10:00 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
