Interior/Exterior Shark Fin on Non Shark Fin Mini (Nav Equip’d)
Old Feb 14, 2008 | 01:46 PM
Peepers's Avatar
Peepers
Hey guys,
My building automatic garage door decided to close / malfunction as I was leaving and it clipped my stubby antenna cause the housing to brake. Since I have to replace the housing anyway, I was wondering if anyone successfully installed an OEM shark fin antenna on a Mini that came with the standard “flexible” antenna?? If so, what are the part numbers I need to order from the dealer???
Peepers
Old Feb 14, 2008 | 02:23 PM
FL_blue_MINI's Avatar
FL_blue_MINI
http://www.realoem.com/bmw/showparts...32&hg=65&fg=50
There's a link to it, but there isn't a part number. I checked the other models, with no avail.
Old Feb 14, 2008 | 05:34 PM
03Indigo's Avatar
03Indigo
User Title's are Silly
Old Feb 14, 2008 | 07:33 PM
Jason C's Avatar
Jason C
The shark fin on top is not the radio antenna, it's for the NAV. The radio antenna is in the rear passenger side window. At least thats how it is on mine, and it's what my MA told me.
Old Feb 14, 2008 | 08:32 PM
Peepers's Avatar
Peepers
I'm in the process of dealing with the building management. I'll post the outcome for those who are curious.
Regarding the parts that I need, when I key in my last 7 VIN# digits, it tells me I need the following http://www.realoem.com/bmw/showparts...07&hg=65&fg=30
When I compare it to http://www.realoem.com/bmw/showparts...32&hg=65&fg=50 it states "No parts found matching your car" and based on the photos it doesn't look like it'll even connect properly?
Thoughts?
Old Feb 14, 2008 | 09:29 PM
Jason C's Avatar
Jason C
^^^See post above^^^
Thoughts?
Old Feb 14, 2008 | 10:05 PM
FL_blue_MINI
Thoughts?
You don't have to use your VIN. You can do a search/browse and look at ALL R50/R52/R53/R56....ect. I did a browse for that part on R50 and R53 in both EU and US. I found nothing.
Old Feb 15, 2008 | 04:02 AM
Peepers's Avatar
Peepers
Jason C - I think might be wrong or your MA gave you incorrect info? My car is equipped with NAV and it ever came with a shark fin. The NAV antenna (GPS) can be seen here #8 http://www.realoem.com/bmw/showparts...57&hg=65&fg=50
Now where all these parts are hidden within that car, I'm not to sure??
FL Blue Mini, I know how realOEM works and the search options. However what I was saying is that the two style antenna's don't look to be interchangeable? It appears that if your car came with a flexible type then you must stick with the flexible type (basing this on the connectors), and visa versa with the shark fin. Can anyone confirm this??
Old Feb 15, 2008 | 09:33 AM
FL_blue_MINI
Im going to guess they are different. But I have no concrete evidence to back that up.
Old Feb 15, 2008 | 09:39 AM
Eric_Rowland's Avatar
Eric_Rowland
As Jason C said, 'shark fin' cars came with the radio antenna integrated into the rear passenger window.
Old Feb 15, 2008 | 10:26 AM
Jason C's Avatar
Jason C
All I know is that I have a radio antenna integrated into my rear passenger glass, and that every MINI I've seen locally that has NAV looks the same.
Good luck on your mission guys.
Old Feb 15, 2008 | 10:39 AM
Eric_Rowland
The '05s had a revised dual purpose antenna base that integrated (or at least co-located) the Nav antenna with the radio, hence the demise of the shark fin.
Old Feb 15, 2008 | 11:57 AM
Peepers's Avatar
Peepers
Well it looks like the property management will be paying for this thus I have to have the dealer perform the work so I doubt they'll install anything other than what my car was orginally equiped with.
It was worth a shot anyway
Peepers
emulajavi
Dec 24, 2018 09:15 AM
Dec 23, 2015 10:36 AM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
kwijmbo
Aug 5, 2015 09:00 PM
