R50/53 What is a good OBD tool that can be used with a laptop?
Old Feb 9, 2008 | 09:55 PM
jeffrimerman's Avatar
jeffrimerman
I used to have an audi and I had a tool that used my laptop to connect and and would give me tons of info. I could even reset my codes and have sensor readings. Is there one for the mini? It is probably the same one since it is a standard, but I wasn't sure.
Old Feb 10, 2008 | 03:18 PM
Modshack's Avatar
Modshack
You used a Vag Com which is an awesome tool for VW's and Audi's. I'm not aware of anything similar for the Mini...
http://www.ross-tech.com
Old Feb 10, 2008 | 03:25 PM
Motor On's Avatar
Motor On
Bim-Com.
Same source, a few select people have beta versions, but it hasn't progressed past that.
Old Feb 10, 2008 | 04:58 PM
Modshack's Avatar
Modshack
Originally Posted by Motor On
Bim-Com.
Yeah...I've seen Andy's posts here...we used to communicate on the Vag Com.. Maybe they're close to a solution..
Old Feb 10, 2008 | 05:07 PM
AstroBlackS's Avatar
AstroBlackS
Well if your willing to pay for it, the GT1 is about as technical as you can get for the Mini.
Old Feb 10, 2008 | 06:04 PM
Longboard110's Avatar
Longboard110
I use auterra for a palm but they do have a windows version for a laptop.
Old Feb 10, 2008 | 07:39 PM
jeffrimerman
Sweet, I will check it out. Thanx everyone.
Old Feb 10, 2008 | 10:59 PM
Nitrominis's Avatar
Nitrominis
I also use the Auterra installed on a Plam. Never leave home without it.
Old Feb 11, 2008 | 12:53 PM
Marino454's Avatar
Marino454
I've used AutoTap before. It's pretty nice, they have palm or laptop versions.
http://www.autotap.com/productcat.asp?topLevelid=36
Old Feb 12, 2008 | 06:39 AM
NOTDULL's Avatar
NOTDULL
OBD II
I found this yesterday... seems like it works with all OBD II vehicles.
http://www.myscantool.com/
Old Feb 12, 2008 | 12:47 PM
redlinedave's Avatar
redlinedave
you gotta loose the Hurst shifter....sorry
Old Feb 16, 2008 | 10:38 PM
Nitrominis's Avatar
Nitrominis
I coulda had a V8
There are two reason for the handle. I have used them for years and like the feel shifting with it. Yes mostly cars with + 4 slugs. If you ever used one you know what I mean. And secondly side button allows easy and controllable activation of my Flame.
quote=redlinedave; "I coulda had a V8"
been there done that a lot !!
http://www.flickr.com/photos/speedra...7600185742433/
Old Feb 17, 2008 | 05:54 AM
asodestrom's Avatar
asodestrom
You might want to check out Autoenginuity
They have pda and laptop versions and their enhanced BMW version has more MINI sensors than the standard package.
Old Feb 21, 2008 | 02:51 PM
frenchie's Avatar
frenchie
I have the autoenginuity scan tool with the BMW enhanced package. I have had some problems with the tool...for example it does not report the MODE$06 information correctly, and the graphs do not scale correctly. I have reported these two failures over a year ago and rather that look into the problem...I was told I was wrong??? These two problems continue to exist, please advise if anyone else has also seen this problem?
Kimolaoha
Dec 5, 2020 09:32 PM
one73ronin
Aug 19, 2015 12:36 PM
Super Coop
Aug 17, 2015 05:09 PM
minipopkart
Aug 13, 2015 05:22 AM
