Suspension know of a diy spring install?
Old Feb 7, 2008 | 06:55 PM
ixotuckeroxi's Avatar
ixotuckeroxi
hey guys,
i think i might try to tackle this one tomorrow morning. i know about the diy files that are sticky in the mod forum but the pics arent working.
does anyone have a diy with pics so that i can reference them during my install? ive done springs before on other cars but i just want to see this info preinstall. thanks
Old Feb 7, 2008 | 07:03 PM
AutoXCooper.com's Avatar
AutoXCooper.com
You may find this link helpful, http://www.txwerks.com/images/Instal...%20Springs.pdf
Old Feb 7, 2008 | 07:16 PM
k-huevo's Avatar
k-huevo
https://www.northamericanmotoring.co...ad.php?t=92737
Old Feb 7, 2008 | 07:19 PM
xsmini's Avatar
xsmini
Randy Webbs how-to no pics but good info.
Nik
Old Feb 7, 2008 | 09:41 PM
ixotuckeroxi
you guys are on it, thanks!
Old Feb 8, 2008 | 12:58 PM
succubus's Avatar
succubus
I found the write up linked by k-huevo to be immensely helpful when I did my TSW install. The job is much easier than the write-up would suggest once you get started. Reading the write-up thoroughly before you start, and making sure you have all of the tools required first makes for a painless couple hours work.
FYI, I used the rubber strap-wrench method (available for ~$15 at Sears) for loosening/torquing the nut on the shaft of the struts.
I also used the buddy method for spring compression and found that it was extremely easy to do this way.
Good luck.
Old Feb 12, 2008 | 04:14 AM
grillhands's Avatar
grillhands
The rears are the easiest springs i've ever replaced. Save them for last, it'll only take you about 20 min to do both.
Old Feb 18, 2008 | 03:50 PM
Downside uP's Avatar
Downside uP
http://engr.smu.edu/rcam/cpm3v/minis...isprings_1.htm
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
adrchn
Aug 13, 2019 02:11 AM
melscoop
Mar 30, 2016 06:56 PM
squawSkiBum
Oct 2, 2015 09:21 AM
