Navigation & Audio Sub with stock radio
Old Feb 2, 2008 | 09:02 PM
TexasCooperS's Avatar
TexasCooperS
Is there any way to hook up a subwoofer with a stock radio? I know I could splice one of the lines for the line in on the amp but I don't want it to be crappy
Old Feb 2, 2008 | 10:01 PM
mistro's Avatar
mistro
looking for the same info...
Old Feb 3, 2008 | 12:15 AM
//MZero's Avatar
//MZero
I'll probably be interested in this sometime in the far future. So bump for stock radio love.
Old Feb 3, 2008 | 08:38 AM
totamdu's Avatar
totamdu
I have the stealthbox and to install it I gutted the inside of the rear and tapped into the speakers there. Its also a good time to put better ones in, since your ripping off the side panels.
Old Feb 3, 2008 | 08:33 PM
murky's Avatar
murky
The typical way would be to get a speaker-to-line-level converter, patch it into the rear speaker wires, hook up an amp-and-sub or powered sub, and go to town.
Old Feb 4, 2008 | 06:23 PM
Some Guy's Avatar
Some Guy
Depends, do you have the HK system?
Old Feb 4, 2008 | 07:46 PM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
I have a sub system hooked up to my "stock" radio. I say "stock" because The head unit and actually wires are still stock. I swapped out the speakers for JBL three ways, 6.5" up front and 6x9" in the rear. I have two Audiobahn 10" subs running on 1200W with a cap. of course. I wired the system quite easily. I used a line level converter. Connected the battery, RCA cables. Tapped into the left rear speaker for ignition and ran a fuse line all the way up to the fuse block and "smashed" it into the fuse that the head unit uses. I know this is not the best way to do it, but it works great and is safe. I have had the system running for almost a year and have had no problems what so ever. This spring I may run a more professional install. I just have to figure it out. Let me know if you need any help. I can take pics in a few days and post them up. I will post some pics now...
Attached Thumbnails Sub with stock radio-100_1578.jpg   Sub with stock radio-100_1580.jpg   Sub with stock radio-100_1585.jpg
Old Feb 4, 2008 | 07:48 PM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
Some more...
Attached Thumbnails Sub with stock radio-100_1584.jpg   Sub with stock radio-100_1587.jpg
Old Feb 5, 2008 | 02:45 PM
Dan00Hawk's Avatar
Dan00Hawk
https://www.northamericanmotoring.co...d.php?t=125146
I just added a sub to my stock non HK system a few weeks ago, pictured above. As mentioned by others, I tapped into the rear speakers for a signal, ran through a line level converter to the amp. I used the rear cigarette lighter for the remote on. Having the battery in the back of the MCS makes things easier, too. Getting the rear interior side panels out and put back in was the most difficult part for me. This was the first time for me hooking up an amp and sub, and it wasn't that bad, and I'm very happy with the results. I'm simply using the head unit's bass level and fader to tweak the bass level now that I'm content with the settings on the amp.
Good luck, and show pics of the setup that you end up using!
Old Feb 5, 2008 | 05:57 PM
05vertible's Avatar
05vertible
so...are non hk systems better to add subs,speakers to?
maxx has the hk stereo i dont like how the speakers have been sounding (flat,no clarity) as chris... i wanted the jbl's also. something eventually like dan...is my dream....
Old Feb 5, 2008 | 08:09 PM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
His looks good
I also made mine so that I can remove everything in like 5 minutes for when I go Auto-Xing.
Old Feb 6, 2008 | 05:37 AM
Dan00Hawk's Avatar
Dan00Hawk
Originally Posted by ChrisMCS04
His looks good
Thanks! Yep, that's an important consideration for some as well. My amp stays put (it's small), but the sub enclosure just lifts right out after disconnecting the speaker wire. It's not a fancy or custom install by any means, as I went for simple and inexpensive.
I like how Chris has his amp and capacitor mounted to the enclosure for easy removal as well as simple access and being hidden from view.
Old Feb 6, 2008 | 10:01 AM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
Thanks. I can have the entire thing be hidden behind the seats(whenever they are actually in the car) But even when my RSD is in the car and my windows being tinted, you really have to be looking to break into the car to see it...unless it is sunny.
TJANK
Sep 14, 2015 10:15 AM
SolCalMini
Aug 29, 2015 07:25 PM
bugeye1031
Aug 15, 2015 08:14 AM
veevsato
Aug 5, 2015 04:42 AM
