R50/53 What does E mean instead of D or P, Help!
Old Feb 2, 2008 | 03:19 PM
nariusb's Avatar
nariusb
I have Mini Cooper 2005 with ems2k DME.
I used winkfpt program to flash/update DME and it took flashing, informed me I still have 12 flashes left.
Now, I can't drive the car.
Auto tranny indicator on the dash, instead of P or D shows E all the time.
Car starts only with gas pedal down and doesn't idle without pressing on the gas peddle.
What is E and how do I get rid of it.
I tried clearing errors in inpa and leaving key in ignition for couple min. NO help.
I cleared adaptation values in INPA and
I tried driving, thinking it needs adaptation reset. No luck
Please help
Old Feb 2, 2008 | 04:16 PM
J_D's Avatar
J_D
E for error?
Old Feb 2, 2008 | 04:52 PM
nariusb's Avatar
nariusb
error
Thanks, that would make sense, but How to get rid of it?
Old Feb 2, 2008 | 05:16 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
What exactly did you do? Some kind of home tuning software? I'd sugest getting it towed to the dealer for an ECU reflash.
Old Feb 2, 2008 | 06:32 PM
Gromit801's Avatar
Gromit801
BTW, welcome to NAM!
Old Feb 2, 2008 | 09:12 PM
chpsk8's Avatar
chpsk8
Please help
Please define the following and we can help you... Sounds like you did something that not many people here are familiar with. You'll have to elaborate on what you did and be very specific with fewer acronyms.
Please define what these are...
ems2k DME
winkfpt program
flash/update DME
inpa
adaptation reset
Old Feb 2, 2008 | 09:16 PM
COR BLMY's Avatar
COR BLMY
I had a 'E " message with the same start issue when I did a customers auto ...
I disconnected the battery for a long time (1 hour) ... did a code read ( reset ) and cleared all codes ... now no signals ... and all is good.
Old Feb 2, 2008 | 09:17 PM
Dr Obnxs's Avatar
Dr Obnxs
Flash back to stock
and see if you get your tranny control back. If so, then I'd guess that your flash file is fubared. Will the car run at all? Was the flash for an auto or manual car? IT's possible that you flashed the car with a program for a manual, and the auto tranny has no one to talk to.
Also, the flash counter isn't really something you need to pay attention to (you may with what you're using, or the factory tools, but many other systems don't incriment the counter when they flash the ECU).
Matt
Old Feb 3, 2008 | 01:29 AM
nariusb's Avatar
nariusb
More details on what I did.
I wanted to update my DME on mini cooper 05, made in 09, 2004, ser# TJ65575.
I used bmw winkfpt flash application with files from progman 2.72 DVD copied to nfs and ediabas folders.
I used inpa before to read what dme i have: ems2k, bmw part#7542310 flashed to 7547294.
As far as I know the flash with winkfpt succeded. I did select ems2k to flash but not sure if the version # was choisen the right one.
Now it sounds that i have no contrlo over CVT auto tranny.
The car starts only with gas pedal pressed, and it has to be pressed to stay running. I runs like crappy.
So either the flash file is wrong or there are some other steps to be done.
I have access to DIS/ GT1. If experts can advise how to preseed, please?
Old Feb 3, 2008 | 05:50 AM
nariusb's Avatar
nariusb
[FONT=Arial]I reflashed manually with a closest flash # I could find and it worked like a charm. Everything is 100% now.[/FONT]
Old Feb 5, 2008 | 03:33 PM
nariusb's Avatar
nariusb
Just to follow up for others. When you update your DME flash be sure to choose the right file from the list. Just open it in notepad and it should say Siemens or John Cooper Works. I flashed the John Cooper works one and that's an upgraded kit which I don't have. That was my problem.
Old Feb 6, 2008 | 11:35 AM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
You might have selected a flash for a manual trans car that did not include the proper information/interface for the auto trans, hence the error.
Glad you got it sorted out.
