Which size 18" tires?
Old Jan 15, 2008 | 06:47 PM
J_D's Avatar
J_D
I just picked up these 18" rims for my new r56 and was wondering which would be better for daily use using the stock suspension. They have a 40mm offset. Any chance of rubbing?
215/40/18 or 215/35/18?
Old Jan 16, 2008 | 08:08 AM
leo@edgeracing.com's Avatar
leo@edgeracing.com
I would keep 215/35R18 so you can avoid messing with the speedometer and odometer readings.
Leo Barrios
leo@edgeracing.com
800-489-5353 x211
http://www.edgeracing.com
NT03+M Sale: https://www.northamericanmotoring.co...d.php?t=125822
Old Jan 16, 2008 | 09:46 AM
pauliekeys's Avatar
pauliekeys
Although I have a R53, to do over again I would have gone with a 215/40/18. There are two guy's in my Mini group running that size on H-sport springs with no problems. I run a 215/35/18 on M7 springs, 42 off set and no rubbing. I'm sure it will be different with the R56 but, I would think you would have more room to work with than the R53. With the 35's I really need to watch for any potholes or bumps or it could be all over for my rims.
Old Jan 16, 2008 | 04:26 PM
Msteadman's Avatar
Msteadman
Assuming those are 7.5" wide or larger, you could also go 225/35/18. Give yourself a bit more sidewall over 215/35 without increasing the profile.
Other thing about 215/35 is it's going to increase the wheel gap if you're not lowering your MINI. Over a half inch smaller diameter than OEM 18's.
Old Jan 16, 2008 | 04:34 PM
PGT's Avatar
PGT
be sure to look at the actual specs of the tire you are buying. they vary widely. 215/35/18 worked well for me
Old Jan 16, 2008 | 05:30 PM
J_D's Avatar
J_D
Unfortunatly i belive these rims are 7" so going to a 225 probably would be a tad to much pinch on the tires.
The 215/35's will be a 1/2" shorter than stock (195/55-16) but the 215/40's are 4/10ths" larger.
Does a 215 bulge enough to protect the rim from a person that paralel parks by braile?
Old Jan 16, 2008 | 05:46 PM
Wolfgang80's Avatar
Wolfgang80
If you want stock diameter, why not go with a 205/40?
Old Jan 16, 2008 | 09:42 PM
pauliekeys's Avatar
pauliekeys
Not for MY Wife !
Old Jan 18, 2008 | 09:08 PM
ezpeasy's Avatar
ezpeasy
205 / 40 with a 7" rim is plenty wide to protect the rim. Also its the only size that is right on the stock diameter.
Kimolaoha
Dec 5, 2020 09:32 PM
Waszak
Oct 21, 2017 05:55 PM
col127
Aug 21, 2015 02:11 PM
Mini'mon
Aug 16, 2015 12:47 PM
Edgar78
Aug 15, 2015 05:33 AM
