R50/53 Red Line
Old Jan 14, 2008 | 11:55 AM
millerjw's Avatar
millerjw
Red Line
I've screwed up a couple of times and redlined my 06 MSC in first. Is there a rev-limiter installed, or am I floating the valves? I'm sure if I don't change my ways something bad will happen..
Old Jan 14, 2008 | 12:24 PM
misslindsey's Avatar
misslindsey
There's a rev limiter - it'll bounce off if you go too deep into redline.
Old Jan 14, 2008 | 12:47 PM
millerjw's Avatar
millerjw
Thanks, sometimes I get a little nuts with the foot and forget.
Old Jan 14, 2008 | 05:45 PM
freeskier's Avatar
freeskier
does anyone happen to know where the rev limiter is on the MCS?
Old Jan 14, 2008 | 05:52 PM
verveAbsolut's Avatar
verveAbsolut
Stock is 6750, I believe.
- Matt
Old Jan 14, 2008 | 06:44 PM
Some Guy's Avatar
Some Guy
6850, almost 100% sure. As long as you dont go way past redline (IE: down shift when you should be up shifting) you shouldn't have any problems.
Old Jan 14, 2008 | 07:39 PM
cooper99's Avatar
cooper99
This topic has already been discussed on here several times; the rev limiter is set at 6950, but you can momentarily go beyond that and rev just beyond 7000rpm.
IMO, daily redlining of your engine at the factory limit is fine. On a factory head, the valves don't begin to float significantly until 8000+ rpm.
Originally Posted by Ryephile
What CmdrVimes means by "6850" is really "6950", but even then, the car will momentarily rev to a bit over 7k. For all practical purposes, it's ~7K for stock rev limit.
Old Jan 14, 2008 | 07:55 PM
HighLife4136's Avatar
HighLife4136
Please don't take this the wrong way, but would you mind letting everyone know how you know that the valves don't begin to float until 8000+ rpm?
Old Jan 14, 2008 | 10:34 PM
cooper99's Avatar
cooper99
Understandable question. For I have never done any research or testing myself . I guess that I have just been on NAM for too long...I recall reading the 8000 limit from a few older threads.
You re-stirred my interest in this particular subject and I did some searching. Isn't learning great! My new conclusion is that there is no exact answer, but significant floating starts to occur somewhere between 7200 and 8125 rpm, with 8000 being the mode.
Some people claimed that floating occurs as early as 6000rpm! Others argue that its not worth upgrading to heavier springs unless you plan on going over 8000rpms. Here is the thread that I am referring to:
https://www.northamericanmotoring.co...ighlight=float
Most the guys posting in that thread really know what they are talking about and are all "experts" in my book (SteveCars60, Johan, herbie hind, obehave, dmh).
Some additional supporting info:
Originally Posted by Motor On
Well if you were to lok around the Electrical Modifications forum, you would find a few threads that covered this, its a shift light,fill the dark spots and its time to shift. Redline stock varies between models. BUt appperently just after 8k rpm you'll float the valves; atleast thats what I've heard.
Originally Posted by MINIotaple
MTH will bump you up to ~7200 I think. I know that there's software that will bump you up higher but you start getting into dangerous territory at ~8000 according to FTR.
Originally Posted by M7
Yes the Motec unit would be great......But it would be absolutly impossible
to use it on the street as all the functions of the ECU would be lost....
And we looked at raising the rpm higher, wich ultimately was not possible
with the stock ECU. At the 8120rpm limit no valvefloat has been detected
or accheived no matter how hard we worked the engine.
peter
Team M7
You will probably find these interesting...
Thread: "Higher Revs"
Thread: "8500 RPM's ???"
Thread: "Valvetrain"
Every year the technology improves and by time I finally decide on a favorite head, some other vendor comes out with a better one!
Old Jan 15, 2008 | 05:37 AM
eager2own's Avatar
eager2own
good info, cooper99 - thanks
Old Jan 15, 2008 | 03:31 PM
beken's Avatar
beken
Redline on my car is somewhere around 6800rpm. Rev limiter kicks in at 7200rpm. I only tested that out once .
Old Jan 15, 2008 | 03:37 PM
AstroBlackS's Avatar
AstroBlackS
I have yet to hit my rev limiter...maybe I should...you know...just to do it once...
Old Jan 15, 2008 | 05:50 PM
HighLife4136
OK..so if you read this thread: https://www.northamericanmotoring.co...ighlight=float
and if in particular you read this post:https://www.northamericanmotoring.co...ighlight=float,
Brain1.0...of FTR...is referring to a 7250 rpm.
And if you read this post by the FTR employee: https://www.northamericanmotoring.co...4&postcount=12
...you'll see that Fireballed does not like the higher rev limits.
BTW, I have my car tuned with extended rev limit by the guys that do the tunes for FTR.
And here's a post about ingsoc regarding this topic: https://www.northamericanmotoring.co...5&postcount=19
If you want to run to 8000/8000+, be my guest
Old Jan 15, 2008 | 06:20 PM
HighSchoolzMINI's Avatar
HighSchoolzMINI
hehehe
GIAC's rev limiter is at
7600RPM
i think
WOOOOO YEA
Old Jan 15, 2008 | 07:32 PM
roaduscarnivorous's Avatar
roaduscarnivorous
in my old car, the rx-7, redlining keeps the rotary engine healthy
Old Jan 15, 2008 | 07:44 PM
DrWhoMini's Avatar
DrWhoMini
Occasionally reaching higher revs can burn out carbon deposits and other things that have detrimental effect.
Old Jan 15, 2008 | 09:56 PM
cooper99's Avatar
cooper99
Thanks for the information in your last post. I agree that running much above 7k rpm on stock valvetrain is risky and not something that I would want to do. However in this thread, we haven't been discussing the issues of raising your rev limiter, but trying to determine when the valves begin to float; which I still believe is somewhere around 8k rpms based upon those previous threads.
What's your rev limit set at with your custom tune?
Originally Posted by HighSchoolzMINI
hehehe
7600RPM
i think
WOOOOO YEA
You could be right, but my GIAC software set the rev limiter at 7200 rpm. Why don't you redline your car one time and find out where it cuts off?
7200 rpm? Wow, are you sure?
Old Jan 15, 2008 | 10:26 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
I feel that the oil pump might not be able to keep the engine oiled at higher than stock rev limits if even that.
Old Jan 16, 2008 | 05:21 AM
Jahmills's Avatar
Jahmills
I hit mine almost everytime I drive the car, after all this time I still have a tendancy to shift from 1st to 2nd late when I'm accelerating hard.
Old Jan 16, 2008 | 04:21 PM
HighSchoolzMINI
[/quote]
[/quote]
well thats something i will do sunday then, another MINY meet thats going up to conneticut, nice open roads
Kimolaoha
Jul 5, 2023 01:04 PM
minimofo
Dec 26, 2015 11:45 AM
caiken
Aug 27, 2015 06:55 AM
PelicanParts.com
Aug 14, 2015 11:07 AM
