R50/53 Window bounce when rolling up
Old Jul 13, 2003 | 08:52 AM
sambusik's Avatar
sambusik
It was a little hot in LA yesterday (about 90), and I was closing my driver side window, it started bouncing.. Basically, it wasn't moving smoothly along the rubber stripping and it would keep hitting it and bounce.
This behavior stopped when the weather got cooler?
Normal? or add it to the list of things I need my dealer to look at?
Old Jul 13, 2003 | 09:03 AM
RonR's Avatar
RonR
Greetings!
The condition you are describing is not normal, regardless of temperature. We've had several weeks of 90+ weather in South florida, and this is the first I've heard of the symptoms you are experiencing !!
Best Regards,
Ron
Old Jul 13, 2003 | 10:12 AM
Sullivan'sDaddy's Avatar
Sullivan'sDaddy
This sounds like an incident that happened to me a couple of months ago . It was a hot/humid day and as I got in the MINI and started to drive off it started to rain so as I rolled the windows up, the drivers-side window started to "stutter" (or "bounce&quot as it went up. I noticed it right away so I rolled it down and rolled it back up again....same result.
A third time it went up smoothly as usual. I haven't been able to replicate the abnormalty again.
(Aside, sambusik, that sig makes me crack up everytime)
Old Jul 13, 2003 | 04:34 PM
kbseto's Avatar
kbseto
haven't had the window bounce problem, but i do have occasional problems with closing the door . sometimes the door isn't able to close because of the window not being aligned correctly. so i gotta turn the ignition and roll down then up the window. then i can close the door. anybody else have this problem? or is this related to the window bounce?
Old Jul 13, 2003 | 04:40 PM
OmToast's Avatar
OmToast
It happened to me last month and I know exactly how to fix it: attempt to show someone the problem and it never happens again!
Old Jul 13, 2003 | 06:06 PM
red03miniS's Avatar
red03miniS
george
i am in la, and it never happend to me
aside from the mishap at the tintshop u referred me to
have teh dealer look at it
u got more probs with ur mcs?
Old Jul 13, 2003 | 06:09 PM
vdubdoug's Avatar
vdubdoug
I had the same thing happen to me once on a really hot and humid day. Has not happened since.
Old Jul 13, 2003 | 09:01 PM
sambusik's Avatar
sambusik
<< have teh dealer look at it
<< u got more probs with ur mcs?
nah, it's been good to me. I'm just keeping a small list of things I want the dealer to take care of when I'm in there next time
- speaker housing buzz
- driver seat creak
Old Jul 14, 2003 | 07:25 AM
joedude99's Avatar
joedude99
It happened to me. A crackhead broke out my window, and it was replaced by the dealer. When you raise the window, it goes to far and adjusts itself downward. The repair guys tell me that the window regulator was also damaged in the break-in and need to be repaired. Hope this helps!
Old Jul 14, 2003 | 07:26 AM
sambusik's Avatar
sambusik
the weird thing is it only happened that one time, I'll probably never be able to replicate it.
Old Jul 14, 2003 | 07:31 AM
dave's Avatar
dave
pug poo picker-upper
We've been in the upper 90s here in denver the last week or so and I have had this happen on about 3 different occations.
Old Jul 14, 2003 | 07:41 AM
MG-BGT's Avatar
MG-BGT
I think you are describing wher the window, as it is moving up, is stuttering or not moving smoothly. This as opposed to where the window, after it has reached the top, does a continued dipping or sewing machine type up-down-up-down for the uppermost 1/4 inch.
I have had both happen to me. The sewing machine motion was probably related to a faulty door sensor or water in the BC1 computer. The stuttering on the way up I am not sure about. It happened on my drivers side window, whcih just last week pooped out, as in, it stopped working. Took car to dealer and they replaced both winding motor and window motor controller. Window is working again now, and currently I have neitehr stuttering nor sewing machine problem. However, my dipping function upon opening door continues to disappear every now and then and I have to reset the auto dip about 1-2 times per week, even today after getting a new motor and controller.
Old Jul 14, 2003 | 07:55 AM
jsun's Avatar
jsun
Just be aware that there are actually TWO problems now being discussed on this thread.
The first (the one that started the thread) is a problem with the LUBRICATION of the wondow mechansim and/or something that contaminates the door weatherstripping (where the glass emerges from the door) that causes the window to stick. I'm not sure that "bouncing" is the best way to describe this. Rather, it's more a sticking and stuttering of the glass when you're trying to raise it. On my car, this is accompanied by a horrible screaming sound. Sort of like fingernails on a chalkboard. It only happens infrequently, and especially when very hot out. Not all cars have this problem, but it's related to the white streak on the window and was written about a lot during the winter (when the supposition was that it was salt).
To fix this, have your dealer check out the operation of the window raising mechanism and perhaps clean/replace the weatherstrip. I wouldn't, btw, be surprised if MINI ultimately issued a service bulletin about this as it does seem to affect certain cars rather obviously (at least the white streak part) but others not at all.
The SECOND problem is an issue with the window glass not "dipping" when you go to close the door. The first thing to try if you're having this problem is to "reset" the window. There are instructions on MCO about this. Try searching "window dip reset" to find the thread(s). Apparently this reset usually works, although some folks have had to have the window motor/electrics replaced.
Old Jul 14, 2003 | 08:24 AM
MG-BGT's Avatar
MG-BGT
sorry for adding to the confusion jsun, didn't mean to bring in additional issues to discuss!
I actually forgot to make the point I first thought of:
my drivers side window first did the stuttering on the way up,
and then about two weeks after that started, it failed. I wonder if the two are related, and if the stutter could be a problem related to the motor controller?
M.
Old Jul 14, 2003 | 09:48 AM
Johnna's Avatar
Johnna
Me too. Driver's side only when it's really hot. It's happened about three times.
My MINI is in the shop today for a few small things. I'll let you know what they say about the window stutter.
Old Jul 14, 2003 | 10:03 AM
Phobol's Avatar
Phobol
Everytime it's hot I get the squeal and bounce. Both are highly irratating. I tried fixing it by cleaning the inside of the weather strip, didn't help. Gotta see the dealer.
Old Jul 14, 2003 | 10:06 AM
antsmini's Avatar
antsmini
I have the same problem. Dealer said its unfixable and it is a result of the hot weather and/or tinted windows.
Old Jul 14, 2003 | 10:08 AM
Phobol's Avatar
Phobol
No tints here...
Old Jul 14, 2003 | 04:31 PM
Johnna's Avatar
Johnna
They replaced the window motor regulator. I'll report if I get the stutter again.
Old Jul 14, 2003 | 04:32 PM
red03miniS's Avatar
red03miniS
>>- driver seat creak
ahh i c
hope it all gets taken care of :smile:
Old Jul 14, 2003 | 04:43 PM
nfo's Avatar
nfo
i've got the bounce/screech going up when it's hot out too!
i've got tinted windows too.
i hope the dealer will fix, they contracted the tint for me.
hmmm.
i'm taking in the car on wed. i'll let you guys know what they say..
Old Jul 14, 2003 | 05:15 PM
jsun's Avatar
jsun
I can't personally speak about the bouncing when it reaches the top, but the screech and dragging has nothing to do with tint (I don't have tinted windows). Rather, it's a lubrication and or contaminated weatherstrip problem. My suspicion is that over time, the extra burden put to the window motor by raising the window through this stuff is eventually burning it out. It's counterintuitive, but for some reason, the stuff drags more when it's hotter outside.
See these two threads (salt streaks and white smudge ) from this past winter. I'm telling ya, it's the same thing...
Old Jul 14, 2003 | 05:20 PM
dominicminicoopers's Avatar
dominicminicoopers
tinted, 118F and no bouncing thank goodness
USNAE2
16
Jun 17, 2022 07:17 AM
bahman
Feb 14, 2016 10:29 AM
vulkandino
Oct 31, 2015 08:29 PM
semibreve42
Oct 2, 2015 09:06 AM
rt808
Sep 25, 2015 01:59 PM
