Big Brake Kits
Old Jan 1, 2008 | 07:54 AM
gary442's Avatar
gary442
Big Brake Kits
Am looking to do a brake upgrade on my 03...lots of options out there.....has any one used these ?
BIG BRAKE KIT FRONT
This kit uses the factory caliper which is relocated to accept a much larger rotor. This is an economical way to increase braking. Requires 17" wheels. Kit includes 324mm (12.75")diameter vented rotors with billet aluminum center, mounting brackets, hardware, and Stainless Steel braided hoses. This is a "bolt on" and does not require any special tools. This kit fit all the factory 17" wheels with out spacers.
Price: $630.00
Old Jan 1, 2008 | 08:36 AM
Detroit Tuned's Avatar
Detroit Tuned
Vendor - 15 Years
that is a rear kit in the photo. are you looking for a front kit?
https://www.northamericanmotoring.com/gallery/data/500/sig36.jpg
www.detroittuned.com ...Making MINIs faster since 2004 Who is DT??? FaceBook
Old Jan 1, 2008 | 08:39 AM
gary442's Avatar
gary442
Front and rears are the same or close to it using this kit...I am looking at the front...
Old Jan 2, 2008 | 11:10 AM
cct1's Avatar
cct1
I'd be careful just doing the fronts, if you're serious about driving it--you're going to alter the brake bias significantly. I'd look for balance--I don't know with that setup if simply changing rear pads would help, but it might not be enough.
Old Jan 2, 2008 | 11:16 AM
gnatster's Avatar
gnatster
There was recently a quite informative thread on the balance issue. Cliff notes is with the proper front setup then one can adjust the balance properly with the correct pad choice on the rear.
Old Jan 2, 2008 | 05:00 PM
Detroit Tuned
Vendor - 15 Years
yeah you can add a front kit and be just fine with only great things like stopping way faster. in fact you can actually add too much rear brake and spin yourself right around. i have seen it too many times.
give me a call if you need help.
Chad
Detroit Tuned
Old Jan 2, 2008 | 08:00 PM
minimarks's Avatar
minimarks
Chad
Detroit Tuned
For the price you are talking about for the kit to relocate the stock calipers, I would take a hard look at Chad's Big Brake Kit for just a few more bucks..
W0TM8
Dec 19, 2019 07:50 AM
thebordella
Aug 31, 2015 01:37 PM
elightbo
Aug 17, 2015 01:50 PM
