Suspension Question to people with Bilstein Sp dampers (Installation issue)
Old Dec 24, 2007 | 08:13 AM
sprp85's Avatar
sprp85
I have been searching around a bit and found out that bilstein sp front dampers are THICKER than the OEM dampers, causing the struts to not to fit properly into steering knuckles.
I installed my H&R coilover (which uses the bilstein sp shocks..) a few weeks back I had some installation issues and I ended up hammering it in... (obvisouly, thicker shafts just doesnt slide in like OEMs.. )
Anyways, I might have to take them out again for a few tweaks soon or later... so could anybody who have experienced the installation issues with bilsteins chime in about how to INSTALL and how to TAKE it OUT without beating the fukc outta the knuckles and the struts.
Thanks in advance.
Old Dec 24, 2007 | 08:39 AM
k-huevo's Avatar
k-huevo
Look here for how to spread the knuckle’s slot https://www.northamericanmotoring.co...ad.php?t=97532 . I installed PSS9s on a GP this past weekend and the struts went in fairly easy using the spreader tool, anti-seize, and some wiggling and jiggling; a ¼ inch drive extension will be similarly effective in lieu of the suspension spreader tool.
Old Dec 24, 2007 | 09:59 AM
sprp85's Avatar
sprp85
should i use the spreading technique when i'm taking the struts out also??
Old Dec 24, 2007 | 12:08 PM
user 7082082's Avatar
user 7082082
I had the same problem with the billstein front struts. A bigger hammer and knocked the knuckle onto the strut. A bit of wd40 and hammering did the job for me.
Old Dec 24, 2007 | 03:14 PM
UKSUV's Avatar
UKSUV
I had absolutely no problems with the install of my PSS9's. They went in super duper quick....
Old Dec 24, 2007 | 06:24 PM
k-huevo's Avatar
k-huevo
sprp85, yes, spread the gap to ease extraction.
Old Dec 24, 2007 | 08:08 PM
sprp85's Avatar
sprp85
i have done hammering so many times on fronts, (my last set was having the same issue.. and it was a different brand too ) i instantly know what to do. I was just wondering if there is a know-how for this
k-huevo// got it! thank you, i will try that 1/4 drive trick next time!
Old Dec 25, 2007 | 08:25 AM
orthomini's Avatar
orthomini
install
yeah, i had the same issue but didnt learn about the spreader until after. i ground off the paint and with corrosion x still wouldnt seat all the way so i had to put the wheels on and set the wheels on the ground to finish the job. removal required hammering but i set a baseball bat on the knuckle and hit the bat with the big hammer.
Old Dec 26, 2007 | 03:33 PM
txwerks's Avatar
txwerks
I spent time sanding some of the paint off the bottoms before installing my SP's - and then, a little coating of anti-seize made them slide right in after spreading the collar just a bit.
Alkaidovich
Jan 30, 2021 01:35 AM
squawSkiBum
Oct 2, 2015 09:21 AM
minipopkart
Aug 13, 2015 05:22 AM
robyb
Aug 8, 2015 06:04 PM
