Navigation & Audio External GPS Antenna...
Old Dec 23, 2007 | 04:30 PM
Motor On's Avatar
Motor On
Anyone running external GPS antenna? I'm running a Garmin c550, mounted in the center of the car I good but not great reception, didn't know if this was significantly better. And if there where any thoughts and or reveiws?
Old Dec 24, 2007 | 12:36 PM
Motor On's Avatar
Motor On
Bumpity. Anyone?
Old Jan 26, 2008 | 05:37 PM
RicardoV's Avatar
RicardoV
Did you read this post:
https://www.northamericanmotoring.co...eferrerid=5625
Old Jan 26, 2008 | 06:00 PM
Motor On's Avatar
Motor On
Yes, I'm not looking to to the replace the OEM though. Also translation of that page makes it very unclear which units that antenna works with.
Was looking at doing a stealth install of this. More trying to determine if it would give me added functionality/accuracy reception in more difficult areas or if it would just be adding wire to the car.
Old Jan 26, 2008 | 06:02 PM
Frank Matyja's Avatar
Frank Matyja
Blew By U
Oooops! Wrong post, sorry
Old Jan 26, 2008 | 06:58 PM
lacning74's Avatar
lacning74
This is what I did with the Gilsson MCX amplified antenna on the front sunroof ledge in my R56. The view of the sky is partially blocked but it gets good enough better reception that I no longer get the signal drop-out driving in NYC that I used to. When I put the antenna on the roof with a full view of the sky, I got much improved accuracy.
This user hid his in the passenger side cowl vent. Not an option in my R56.
Originally Posted by THE ITCH
I have mine mounted under the passenger side cowl vent. I fabricated a bracket out of some sheet metal, sprayed it black, and used existing bolts to mount it. I have both the GPS and sirius pucks there and receive good reception. It is a very stealth install.
Steve
Old Jan 27, 2008 | 05:12 AM
THE ITCH's Avatar
THE ITCH
I was also looking for a stealth install on my GP. I ended up mounting the antenna puck under the passenger side cowl duct. I just purchased some thin metal, fabed up a bracket, and secured it with one existing bolt and some velcro. I get good reception from there and you cannot tell there is GPS in the car.
Steve
Old Jan 27, 2008 | 06:09 AM
snapper's Avatar
snapper
I was also looking for a stealth install .... I get good reception from there and you cannot tell there is GPS in the car.
I would also try and go beyond "stealth" to "invisible," especially to someone that knows what to look for. Check out this thread out: Clicky
Old May 26, 2008 | 10:49 PM
Motor On's Avatar
Motor On
Steve
I took your idea and ran with it, here are some photos, tested it out tonight and I can get full signal while completely in the garage with the door closed!!! Doubt I'll lose signal ever again
Used some left over steel brackets from my old DIY front plate tow hook mount, used a bolt for the plastic trim and there is zero external visibility of the GPS system when I take it down from the interior now
Old May 30, 2008 | 09:55 AM
lacning74's Avatar
lacning74
Awesomely stealth, and of course, well photographed.
Old May 31, 2008 | 07:52 AM
THE ITCH's Avatar
THE ITCH
Motor On
Great job!! Thanks for taking the time to photograph. I also have my satalite radio hockey puck in the same area.
Steve
Snapper
I never liked to have an array of electronics bolted to the dash that says "Take Me" so I decided to do an indash flip screen. I had the Kenwood unit installed and it fits the theme of the stock controlls pretty well. Some one would have to know what to look for to recognize it. I'm sure that they are out there and hope that they don't find me.
Steve
Old Jan 20, 2010 | 12:56 PM
PinesMini's Avatar
PinesMini
do you think you can re-post pics? Thanks
elverado
Jan 18, 2022 02:51 AM
vetsvette
Oct 2, 2015 07:09 PM
Emnotek
Sep 29, 2015 07:37 AM
Greezyman
Sep 21, 2015 05:31 AM
Sep 11, 2015 11:09 AM
