Tire pressure for 205/55-16 tires.
Old Dec 16, 2007 | 05:44 PM
gmua's Avatar
gmua
What would be the recommended tire pressure, once I change my stock 195/55-16 Run-Flat tires, for a new set of 205/55-16 regular summer tires, should I stay with the recommended 30 psi or increase it a little.
TIA,
Guillermo.
Old Dec 16, 2007 | 05:53 PM
Crashton's Avatar
Crashton
Welcome to NAM
I run my non-runflat 205/50/16's at 32 psi. That would be a good starting point for you. See how you like that & adjust accordingly.
Old Dec 17, 2007 | 02:40 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
TIA,
Guillermo.
What year and model MINI do you have?
The new R56 MINI runs a higher pressure than the older models.
Look on your driver's side door jam- there is a plate there with all of the recommended pressures. They are not based on which tire you use, it is based on your car's weight and the load you carry- 2 vs 4 people.
For 2002-2006:
For two people run about 35 psi front and rear for all tires runflat or not (street use).
For four people run about 38 psi front and rear for all tires.
Search- this topic has been discussed before.
Old Dec 17, 2007 | 06:43 AM
FP's Avatar
FP
I've had the same question. The side door tag only gives you information on the tires that came with the car. Mine came with 15" wheels and I changed to 16s (205/50-16) for winter, and 17s (205/45-17) for summer.
Old Dec 17, 2007 | 07:41 AM
minihune's Avatar
minihune
The tire pressures are the same no matter the diameter of the wheel.
It is based on the weight of the car and the load.
Old Dec 17, 2007 | 08:03 AM
FP's Avatar
FP
Really? Good to know thanks.
Old Dec 17, 2007 | 10:04 AM
gmua's Avatar
gmua
Thanks guys, 32 psi is what I was thinking, because I mostly drive alone and I have a 2004 R50. The reason I asked (sorry for double posting) is because I couldn't find any posts about this specific size of tire (205/55-16) and I mistakenly taught that air pressure was relative to tire size.
Old Dec 17, 2007 | 10:10 AM
gmua's Avatar
gmua
Thanks for the welcome Crashton...
khumpert
Nov 30, 2015 11:48 AM
oldkid6
Aug 30, 2015 08:28 AM
TJANK
Aug 24, 2015 06:11 PM
nomar116
Aug 9, 2015 09:42 AM
