Cold Weather Package
Old Dec 15, 2007 | 08:57 AM
scribbledpaper's Avatar
scribbledpaper
the land of far, far away
and this morning, even though my car was warmed up, I was not able to spray my windshield in order to wash it. It is about 8 degrees outside, but again, the engine was warm so aren't the sprayers supposed to be heated? Has anyone else had this problem?
Old Dec 15, 2007 | 09:28 AM
sliboa's Avatar
sliboa
From what I understand, the sprayers, as well as the wing mirrors, are heated when you turn on the rear defroster.
Old Dec 15, 2007 | 09:35 AM
TurboBlu's Avatar
TurboBlu
yes, they are all tied in to the rear window defroster
Old Dec 15, 2007 | 09:39 AM
terrytrucker's Avatar
terrytrucker
i don't think that is correct. the manual states that the mirrors heat when the temperature drops below a set degree. I think it also mentions the washer jets. The rear defroster is on a timer. Wouldn't you hate for your washers to not work because the time expired on the rear defroster? No good.
Old Dec 15, 2007 | 10:28 AM
Robin Casady's Avatar
Robin Casady
Page 31 of the PDF manual:
At outside temperatures below a certain limit,
both exterior mirrors are automatically heated
while the engine is running or the ignition
switched on.
Do not use
the washers if there is any danger that the fluid
will freeze on the windshield. If you do, your
vision could be obscured. For this reason, use
antifreeze.
Window washer nozzles
The window washer nozzles are heated automatically
is switched on*.
* Indicates special equipment, country-specific
equipment and optional extras, as well as equipment
and functions not yet available at the time
of printing.
Old Dec 15, 2007 | 10:44 AM
jmdor's Avatar
jmdor
Of course, we all know that the manual was printed once, and a number of things have changed since then....
Old Dec 15, 2007 | 11:10 AM
Sowellman's Avatar
Sowellman
I've seen no indication here, on Mini2 or on Motoringfile to indicate that the windshield spray nozzles or the wing windows are controlled by the rear defroster. Please note your source.
Old Dec 15, 2007 | 12:13 PM
TurboBlu's Avatar
TurboBlu
i just figured it worked the same way as My 07 Silverado.
My silverado when you turn the rear defroster on it does mirrors as well.
just assumed, never really looked into it, hasn't been cold enough around here to try it.
Old Dec 15, 2007 | 01:08 PM
Minidrivr's Avatar
Minidrivr
8 degrees is pretty cold. I wonder if the jets are heating fine but the lines to the jets are frozen. How warm is the car? Do you have a water temp gauge in it?
Old Dec 15, 2007 | 02:20 PM
ghosthound's Avatar
ghosthound
i would imagine after the engine has been on for some time, there is enough heat under the hood to keep everything nice and toasty... heck, its hot enough to melt peoples hoodscoops i think it should be enough to keep the washer fluid a liquid!
Old Dec 15, 2007 | 03:39 PM
PHX ATC's Avatar
PHX ATC
Who the hell lives where it is 8 degrees?
Ah, never mind!
Old Dec 15, 2007 | 05:10 PM
MrVvrroomm's Avatar
MrVvrroomm
Ah, never mind!
-8 as I type this right now. Washers work fine.
Old Dec 16, 2007 | 04:55 AM
ibnarabi's Avatar
ibnarabi
Mine worked fine at -1 today, they work great actually.
I only turn on the defroster to heat the rear window up so I don't get steaking when the liquid drys.
Old Dec 16, 2007 | 04:10 PM
Reese's Avatar
Reese
-8?
-21 this morning here in rural Colorado high valley. Haven't got my MINI yet (waiting to be shipped), but I did order the CW package and we'll definitely put it to the test!
Old Dec 16, 2007 | 06:36 PM
sliboa's Avatar
sliboa
When I bought my '06 last year, that's what my MA said. I don't think I even looked for it in the manual.
Old Dec 16, 2007 | 06:51 PM
Kilted's Avatar
Kilted
Its 27 degrees hear and a wind chill has it at 16. That said I feel bad complaining about the weather (-8,-this,-that) . Forget the washers, I don't work that well below 25 degrees .
Old Dec 16, 2007 | 07:09 PM
eejphotog's Avatar
eejphotog
My MA said the heated mirrors and nozzles turned on when the heated seats were turned on. I just assumed that's the way it was set up, but I haven't checked.
potterstein
Dec 30, 2024 05:18 PM
molala
Oct 2, 2015 01:53 PM
dandw2
Sep 6, 2015 03:14 PM
tylewis
Sep 6, 2015 01:07 PM
