Navigation & Audio Adding an amp to a stock non-H/K system
Old Dec 5, 2007 | 01:11 PM
doug4442's Avatar
doug4442
Is the stock, non HK system wired to accept a pre amp? If it is, and I add an amp I'm assuming this wouldn't interfere with the steering wheel controls. Am I right?
The delema is that if I go with an aftermarket head unit, I loose the steering wheel volume/switcher control, unless I go with a high end head unit plus some sort of $200 unit to make the controls work.
Is it easier to just add an amp to the original system? Will I likely regret not replacing the head unit because of it's quality (or lack there of)?
Old Dec 5, 2007 | 02:52 PM
shankrabbit's Avatar
shankrabbit
No pre-amp on H/K or non-H/K. You'll have to snag it line level.
Old Dec 5, 2007 | 03:06 PM
rkw's Avatar
rkw
Adding an amp wouldn't interfere with steering wheel controls. The OEM head unit doesn't have line out, but many aftermarket amps have both line level and speaker level inputs, or you can use a speaker level to line level converter box.
theblackfalcon
Oct 11, 2015 09:49 AM
SunnySideUp
11
Aug 26, 2015 06:42 AM
Emnotek
Aug 13, 2015 05:47 PM
Lee-Oh_825
Aug 11, 2015 10:27 PM
