Suspension qwik question
Old Dec 4, 2007 | 10:34 PM
astromini's Avatar
astromini
qwik question
hey everyone..
i just got my M7 STB! and i have mushrooming both left and right... to get it flatten do i need to take off the struts then pound it with woo/hammer or i can just jack it up and just unbolt it then wood/hammer it! what should i do? is it dangerous to intsall the bar when its not really flat?
thnx
ace
Old Dec 5, 2007 | 07:22 AM
txwerks's Avatar
txwerks
I would recommend jacking the car up and dropping the struts down out of the towers... Then, massage liberally with a hunk of 2x4 and a BFH.
Old Dec 5, 2007 | 09:34 AM
JustJAY's Avatar
JustJAY
That werks, , as well. What I have done on 3 MINIs now is jack up and pound with a 2X4 and a heavy rubber hammer. Cover the 2X4 with a cloth and go at it.
Old Dec 5, 2007 | 11:16 AM
astromini's Avatar
astromini
justjay : did remove the struts?! or u just pounded with the struts and bolts still intact?!?!
is it dangerous to not have it flattened and installed?!?
Old Dec 5, 2007 | 11:22 AM
UKSUV's Avatar
UKSUV
Well...just to let you know..I had my 3-series' left tower replaced (3'' deviation) to the cost of $6K....so good luck with whatever you decide...
Old Dec 5, 2007 | 12:01 PM
astromini's Avatar
astromini
should remove the struts or its ohk to pound it with the struts and bolts still intact?!?
Old Dec 5, 2007 | 12:02 PM
txwerks's Avatar
txwerks
I would remove the struts, personally. Or, at least remove the bolts and drop them down into the towers...
Old Dec 5, 2007 | 03:37 PM
succubus's Avatar
succubus
Yes, just remove the nuts and jack the car up. the struts will fall down out of the tower as you jack up the car.
Then pound flat. It helps to have a friend to guide the struts in/out.
Old Dec 5, 2007 | 05:19 PM
astromini's Avatar
astromini
yeh kk i will drop the struts! do i need to remove the wheels? all i need to do to drop the struts is remove the top 3 bolts and it will drop or is there anything else i need to unbolt?
Grizld700
Dec 30, 2015 10:47 AM
donniedarko
Oct 21, 2015 01:15 PM
twriter
Oct 2, 2015 03:14 PM
Carwash
Sep 15, 2015 02:02 AM
marc0011
Sep 10, 2015 10:04 PM
