R50/53 ONE Month OFF
Old Nov 29, 2007 | 09:12 AM
dominos's Avatar
dominos
ONE Month OFF
hi guys -
what do i need to do if i plan to leave my car in the garage for a month? and how?
do i need to disconnect something?
im just afraid when i get back fom vacation, my MINI is dead. :(
thanks,
dominos
Old Nov 29, 2007 | 09:14 AM
Yucca Patrol's Avatar
Yucca Patrol
I wouldn't worry about it. My MINI sat unused for a month this summer and all I did when I got home was start it up and take it for a drive. Only thing I noticed was a little bit of extra smoke for 2 seconds when it started up.
If you want to, you can disconnect the battery or get an inexpensive trickle charger and connect that to the battery. (I did neither of these)
Old Nov 29, 2007 | 09:25 AM
navycav3's Avatar
navycav3
it should be fine, the worst you would have to do is jump it when you get home, but i reall doubt you would have to do that
Old Nov 29, 2007 | 09:27 AM
Eric_Rowland's Avatar
Eric_Rowland
Originally Posted by Yucca Patrol
...If you want to, you can disconnect the battery or get an inexpensive trickle charger and connect that to the battery. (I did neither of these)
+1
A month isn't a big deal, just make sure you check the tire pressure when you get back, and maybe pop the hood and make sure a mouse hasn't made a new house.
Old Nov 29, 2007 | 09:32 AM
adam76's Avatar
adam76
And don't forget to bring your MINI a present back from your vacation.
Old Nov 29, 2007 | 09:43 AM
misslindsey's Avatar
misslindsey
My old POS Alero even started up after sitting in the driveway for close to 2 months. I wouldn't worry about the MINI, just make sure nothing has made a home in a wheel well or engine bay while you were away.
Old Nov 29, 2007 | 11:18 AM
tdm156's Avatar
tdm156
Ruling the curves
No worries. Mine has sat several times for a month or more with no issues. I usually try to make sure I have less than a half a tank of fuel and always check the tire pressure and oil before starting her up again!
Old Nov 29, 2007 | 11:22 AM
dominos's Avatar
dominos
whats the reason to have less than half tank?
thanks
Old Nov 29, 2007 | 09:03 PM
chpsk8's Avatar
chpsk8
If it's cold then have a FULL tank to eliminate any moisture build up. Other than that you're fine. Just think, cars sit on the dealer lot for many months without ever getting touched... ok maybe not a Mini, but think of all those domestics sitting.
Now if you were talking about 5 months... then we need to talk.
shorenetworks
Nov 4, 2019 06:18 PM
Klenk
GP Talk
Sep 16, 2015 11:29 PM
sempaipaul
Sep 14, 2015 09:16 PM
USA-RET
Sep 8, 2015 01:50 PM
dandw2
Sep 7, 2015 11:14 AM
