Clutch question
Clutch question
Hey guys Iam looking into getting an upgraded clutch for my mini what do you guys suggest?
Also does anyone have a megan racing header and there cat-back system installed? If so do you have a sound clip
i would go oem clutch and light flywheel, im installin mine uuc flywheel http://www.uucmotorwerks.com/ go find product n u can see it
OEM Clutch
The stock clutch is fine at least to 130bhp, which is what our JCW MC's are making...Mine lasted 2 seasons of road racing, and I just couldn't stand it any more and took it out after a 24-hour race....the mechanics were shocked, as it still looked good.....changed it anyway, for peace of mind.
If you are not racing the car, go with a lighter flywheel and lightweight crank pulley, light wheels, etc.....check out Wilwood front brakes rather than the AP/Brembos....you lose 5 pounds per corner of unsprung weight. Note: If you are on the street, don't go too extreme on the flywheel weight reduction, as the noise will increase to a level you may not be comfortable with, day in and day out.....
Cheers!
Stephen.
Cheers!
Stephen.
Have a Spec stage II clutch and a Fidanza flywheel. They're both great and I have no noise to go along with it. Before I had them installed, I was warned about the possible noise the flywheel would give, but no problems here.
Just my two cents....
Sounds great!
I'm in NC and was talking to Dan at Grass Roots Garage. He recommended the same set up. Glad to hear another success story. Looks like a go!
I used the Clutchmasters Flywheel and Kevlar stage 3 clutch(from Revolution) set on mine...Didn't want to overtax a stock clutch disc. Seemed to be real grabby at first, but I have gotten much better at driving it. I pulled it out and checked it 10k later after blowing my trans and it looked perfect. Big difference with the flywheel, I would say it to be one of the best upgrades I have done performance wise.
Chad
Chad
andrewjg1994
Jan 29, 2021 07:45 PM
Sep 17, 2015 09:27 AM
