Suspension Alignment needed after drop?
Old Nov 14, 2007 | 03:44 PM
hemiheaded18's Avatar
hemiheaded18
My car is still at factory ride height and prolly will be for a while but I'm always thinking. My ideal setup is TSW springs on Koni yellows. Now, my question is, after reading all of the stories of needing plates and rear control arms, are they really needed after a slight drop? I know if you really slam it, then, yes. But, the TSW springs are good for what, 7/8 of an inch? Will even a slight drop screw up camber enough to need that stuff of will it be good where it ends up? I also know to really use it to it's full potential, then get plates and control arms but still, am I really gonna push it that hard?
Old Nov 14, 2007 | 03:46 PM
UKSUV's Avatar
UKSUV
With just springs...from what I've read and eperienced is No....you dont need an alignment. Once you run coilovers...then thats a different story. I guess it just all depends how well the car settles.
Old Nov 14, 2007 | 03:49 PM
Yucca Patrol's Avatar
Yucca Patrol
I'm of the opinion that anytime you mess with suspension you should do an alignment.
The tire shop I go to has the latest Hunter alignment machine. For only $70 I have lifetime alignment and can take it back anytime I feel like it.
Best deal in auto service I've ever had.
Old Nov 14, 2007 | 03:53 PM
hemiheaded18
That is a good philosophy. But, on a fairly tight budget and the MINI having little adjustment, it raises some questions like "Do I really need to spend an extra $300-500 just to get it 100% or can I be good at say, 90%?
Old Nov 15, 2007 | 11:04 AM
90STX's Avatar
90STX
Raising or lowering our cars changes the toe settings. To much toe (in or out) can really chew up tires.
All year MINIs are adjustable for toe in the front and rear.
Get an alignment.
Scott
90SM
Old Nov 15, 2007 | 11:16 AM
PenelopeG3's Avatar
PenelopeG3
An alignment is much cheaper than replacing 4 worn out tires. Get it. I guarantee the alignment will be out of spec after changing things.
Old Nov 15, 2007 | 03:44 PM
Spinley's Avatar
Spinley
I just had my OM coilovers and new shoes installed last week. My steering wheel is shaking when I'm above 3k RPM now. According the BR Racing (the shop that installed my coilovers) said, let the suspension settle, and then have your wheels re-balanced and do alignment.
Old Nov 15, 2007 | 03:49 PM
UKSUV's Avatar
UKSUV
Yeah....give the coilovers a good 1K miles of good driving. Mine were settling for quite awhile. The shaking is probably caused by an ill-balanced wheel/tire. You running hub rings? BTW, my car is slammed and my steering wheel doesnt shake at all from the coilovers. They actually HELPED with vibrations caused by my tire/wheel balancing issues. And my camber is craaazzzzzy.
Old Nov 15, 2007 | 04:11 PM
meh's Avatar
meh
I installed TSW springs and after having it aligned found that the toe was out (both front & rear) also I was able to bring the rear camber to a reasonable amount. Fortunately I did not have to change the control arms on my 06 and the alignment cost $50 for front & rear.
Old Nov 15, 2007 | 06:53 PM
Spinley's Avatar
Spinley
How ironic, I was actually going to wait till I hit 1k miles of driving (3mos worth of driving for me) before I get an alignment/re-balance. I am running hubcentric, you think that may be the reason for steering wheel to shake at 3k RPM? If so, I'll remove the wheels and check if hubs are tightly snug.
Old Nov 15, 2007 | 07:03 PM
tazio's Avatar
tazio
There should be no need to "re-balance" your wheels. Balance is completely unaffected by suspension settling.
Old Nov 15, 2007 | 07:09 PM
jeffc's Avatar
jeffc
7th Gear
I ate up a set of tires when I dropped my car with springs. I recommend adjustable lower rear control arms and alignment.
Old Nov 15, 2007 | 07:11 PM
Spinley's Avatar
Spinley
Hey Taz,
So you telling me just wait it out - let the coilovers settle and steering wheel will stop shaking?
Old Nov 16, 2007 | 10:36 AM
hemiheaded18
I forgot about toe. I should remember after doing alignments on Volvos for 6 months. But, what about camber? I know I should get it checked. The problem lies in the fact that my car is an 2003, very little camber adjustment. I guess if I'm going to do it, I should do it right. But the control arms which aren't deathly expensive and maybe check into IE plates.
Old Nov 16, 2007 | 12:49 PM
UKSUV's Avatar
UKSUV
Thanks but that wasnt the issue I was addressing with that comment. It was towards the vibration issue.
Old Nov 16, 2007 | 12:59 PM
90STX's Avatar
90STX
Lowering the car will noticably increase negative camber in the rear, but not impact camber too much up front. Neither change in camber is enough to impact tire wear. It is the toe change that will do in the tires pretty quickly. IIRC, lowering the car increases toe-in, raising it increases toe-out.
Your car will certainly handle better if you install the camber plates and rear arms so you can set the camber to better specs, but it isn't really necessary.
Scott
90SM
Old Nov 19, 2007 | 02:41 PM
hemiheaded18
Scott
90SM
Thanks. Thats was pretty much what I was looking for and kinda figured all along but wanted a confirmation. Oh, yeah. And this puts me at a 1,000 posts.
Alkaidovich
Jan 30, 2021 01:35 AM
maestro39
Oct 27, 2015 02:38 PM
iwant2knowwhois
11
Sep 19, 2015 12:18 PM
Minibeagle
Aug 13, 2015 10:00 AM
minipopkart
Aug 13, 2015 05:22 AM
