Rattle in rear sway bar link R56
Old Nov 9, 2007 | 06:16 PM
pasuriole's Avatar
pasuriole
I have a rattle coming from a rear sway bar link. When the car is rocked side to side it is very pronounced on the right side. I can easily slide the sway bar through the grommets that hold the sway bar in place and was wondering if this is normal? When I do this I notice that the top of the sway bar links move in and out with the sway bar. Has anyone encountered this problem, and if so what was the fix
Old Nov 10, 2007 | 05:13 AM
Krut's Avatar
Krut
First I've heard of it - although not uncommon if you've upgraded to an aftermarket rear sway bar and the bolts are not completely tightened.
Depending on how far you are from a dealer your options are take it in and get it fixed or crawl under the car, inspect and tighten the bolts if you're handy. I personally would take it to the dealer.
Old Nov 10, 2007 | 02:49 PM
r56mini's Avatar
r56mini
tighten it. when I took mine out to replace with a 19mm adjustable one it was very tight so I tightened very tight as well.
Old Nov 30, 2007 | 08:08 AM
ZIG's Avatar
ZIG
I had some noises from the rear of the car recently, so made an appointment to have it looked at. Took the car in this morning and was told the sway bar was loose at the bushings and they would order the parts to fix it Monday. Could not give a reason this happened, so I just took a loaner and should get my car back Monday evening. 6000 miles on odometer, and all parts are stock.
As promised the parts came in on Monday and I picked up my car after work. The invoice says they replaced 2 stabilizer supports and 2 rubber mountings, and also washed my car for me, so I was pretty happy with the service which was covered under warranty. No rattle noise at all now.
Old Dec 11, 2007 | 06:58 PM
pasuriole's Avatar
pasuriole
I finally resolved the problem. I had new bushings put in under warranty. It seems the wrong bushings were put in at the factory. It seems to be a common problem that mini is not addressing unless there is a complaint.
Old Jul 29, 2008 | 09:41 AM
hardcharger's Avatar
hardcharger
Sorry for reviving an ancient thread, but can anyone tell me if this rattle sounded like it was inside the back of the car? I've got a rattle back there that is driving me nuts. I've pulled everything loose out and can't figure out where it is... if it's the swaybar, that'd explain why I can't find it inside.
Thanks!
Old Aug 10, 2008 | 09:12 AM
JAS76's Avatar
JAS76
I am getting this sound as well, just had springs and sway bar installed, took it back to them and made sure everything was tight. Still have this sound in the rear??
Someone mentioned replacing bushings through dealer under warranty?
Correct me if i am wrong, but doesnt the H&R sway bar come with its own bushings when getting installed into brackets?
Since i have aftermarket, sounds like the dealer may charge me ah?
Any thoughts?
Toolman
Jan 20, 2016 06:50 AM
nomar116
Aug 10, 2015 11:24 PM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
