Will 17X8 Motegi Wheels work?
Old Nov 9, 2007 | 12:31 PM
BoomerMCS's Avatar
BoomerMCS
Need expert advice. Found new Motegi Traklite 2 wheels but the only size is 17 X 8. They have a +42 offset and backside of 6 1/8.
Checked 18" JCW wheels and even these are 7" wide. Would think tire size would be important consideration. With an 8" width could probably run 225's on these rims but section width of the tire would be approaching 9".
How can I assure myself that these will work?
Does anyone run this wide a tire? Any issues?
Car is at stock height but planning to lower with H & R springs. Will this create a problem?
Thanks for your help.
Old Nov 9, 2007 | 01:10 PM
Wake|MCS's Avatar
Wake|MCS
You may want to consider spacers but they might not be necessary. As for the drop, with the 225 you may rub, but who knows... Not too many people on here run wheels wider than 7.5" but I'm sure Rally will chime in as he knows his shyt...
Old Nov 9, 2007 | 02:15 PM
kyriian's Avatar
kyriian
a member in our club is running traklite 2.0 17x8, not lowered, and he says its fine
although with lowering i can see a BIG amount of rubbing
Old Feb 8, 2008 | 12:31 PM
terryg's Avatar
terryg
I'm getting a set for the R56, so when they get here I'll try one on the R53. I'm assuming they are going to rub like crazy in the smaller wheelwell.
Old Feb 8, 2008 | 01:04 PM
mcs22004's Avatar
mcs22004
Don't know about your offset. This guy has 17x8.5 RH AQ Maxilite As with an effective offset of ET35, albeit with the wrong size tires. Altogether far from an optimal solution, but they look great on the car and contact is supposedly under control. This other guy is buying the exact same wheels and the same size tires.
Thus it would seem that it is possible to get 17x8s on the car with the correct offset--whatever that is.
Old Feb 8, 2008 | 01:17 PM
PGT's Avatar
PGT
if you have stock suspension, 17x8ET42 is about perfect. You need to be careful with tire size though. Also, coilovers make fitment tougher
Old Feb 10, 2008 | 06:13 AM
a610's Avatar
a610
Do a search for 235/40/17. There is somebody here who runs/ did run that wheel and tire combination.
Old Feb 10, 2008 | 10:28 AM
tschwalbe's Avatar
tschwalbe
I have the traklite 2's on order they should be here monday. I opted for 215/45/17 kumho esta spt's I wanted 225/40's but didnt want to chance rubbing i will post how they fit on my 2006 MCSa
Old Feb 10, 2008 | 04:58 PM
PGT's Avatar
PGT
SPT is a soft tire. Hope it does ok for you.
Old Feb 10, 2008 | 06:26 PM
kyriian's Avatar
kyriian
everyone seems to knock SPTs... but i didn't find the problems that others have found... ... i can't say i love it enough to buy again though
different batch perhaps
Old Feb 10, 2008 | 06:29 PM
PGT's Avatar
PGT
I had them in 15". So soft, the car would shimmy sideways when closing the doors. They road like butter, but absolutely no steering response, which was quite upsetting. I should have kept the RG-F, but put proper rubber on them. Oh well....hindsight = 20/20. They wouldn't have cleared my brakes anyways
penguinhomey
38
Jul 7, 2019 09:24 PM
jrezzo
Aug 9, 2015 10:32 PM
nomar116
Aug 9, 2015 09:42 AM
nismo4life
Aug 5, 2015 08:31 AM
