Off-Topic :: Autos Interested in discussing other autos? This is the place!
Nissan GTR
Old Nov 9, 2007 | 10:20 AM
windsorlove's Avatar
windsorlove
Nissan GTR
http://www.gtrnissan.com/
Engine
• VR-series twin-turbocharged 3.8-liter V6.
480 hp @ 6,800 rpm. 430 lb-ft torque @ 3,200–5,200 rpm.
• Dual overhead camshafts with variable intake-valve timing.
• Cast aluminum cylinder block with high-endurance/low-friction plasma-sprayed bores.
• IHI twin turbochargers, one per cylinder bank.
• Pressurized lubrication system with thermostatically controlled cooling.
Drivetrain
• ATTESA ET-S All-Wheel Drive (AWD) with independent rear-mounted transaxle integrating transmission, differential and AWD transfer case.
• Rigid, lightweight carbon-composite driveshaft between engine and transaxle.
• Electronic traction control plus 1.5-way mechanically locking rear differential.
• Vehicle Dynamics Control (VDC-R) with three driver-selectable settings: Normal (for daily driving, controls brakes and engine output), R-Mode (for ultimate performance, utilizes AWD torque distribution for additional vehicle stability) and Off (driver does not want the help of the system).
• Hill Start Assist prevents rollback when starting on an incline.
DisclaimerVDC-R cannot prevent accidents due to abrupt steering, carelessness, or dangerous driving techniques. Always drive safely.
Transmission
• 6-speed Dual Clutch Transmission with three driver-selectable modes: Normal (for maximum smoothness and efficiency), Snow (for gentler starting and shifting on slippery surfaces), and R mode (for maximum performance with fastest shifts).
• Fully automatic shifting or full sequential manual control via gearshift or steering wheel-mounted paddle shifters.
• Dual clutch design changes gears in less than 0.5 second (0.2 second in R mode).
• Downshift Rev Matching (DRM).
• Predictive pre-shift control (in R mode) based on throttle position, vehicle speed, braking and other information.
Wheels and Tires
• 20 x 9.5" (front) and 20 x 10.5" (rear) super-lightweight forged-aluminum wheels with Gunmetal Gray finish.
• Exclusively developed nitrogen-filled Bridgestone® RE070A high-capacity run-flat summer tires, 255/40R20 front and 285/35R20 rear.
• Tire Pressure Monitoring System (TPMS).
• Optional exclusively developed nitrogen-filled Dunlop® run-flat all-season tires, 255/40R20 front and 285/35R20 rear (includes Bright Silver wheels).
Brakes
• Brembo® 4-wheel disc brakes with 4-wheel Antilock Braking System (ABS), Brake Assist, Electronic Brakeforce Distribution and Preview Braking.
• Two-piece floating-rotor 15-inch front and rear discs with diamond-pattern internal ventilation.
• 6-piston front/4-piston rear monoblock calipers.
Steering
• Rack-and-pinion steering with vehicle-speed-sensitive power assist.
• 2.6 steering-wheel turns lock-to-lock.
Suspension
• 4-wheel independent suspension with Bilstein® DampTronic system with three driver-selectable modes: Normal/Sport (for automatic electronic control of damping), Comfort (for maximum ride comfort), and R mode (engages maximum damping rate for high-performance cornering).
• Electronically controlled variable-rate shock absorbers. High-accuracy progressive-rate coil springs.
• Front double-wishbone/rear multi-link configuration with aluminum members and rigid aluminum subframes.
• Hollow front and rear stabilizer bars.
Body/Chassis
• Exclusive Premium Midship platform with jig-welded hybrid unibody.
• Aluminum hood, trunk and door skins. Die-cast aluminum door structures.
• Carbon-reinforced front crossmember/radiator support.
wow. but can someone explain the nitrogen filled tires?
Old Nov 9, 2007 | 11:16 AM
hemiheaded18's Avatar
hemiheaded18
Nitrogen is not as sensitive to temperature and therefore pressure change the same way air is. It holds a given pressure more steadily and will not fluctuate as much due to ambient temperature change or the vehicle being driven.
Old Nov 9, 2007 | 11:20 AM
nicknbecka's Avatar
nicknbecka
Specs sound like it could be a fun drive
The nitrogen expands/contracts less over temperature changes, for more consistent tire pressure. Don't forget that your 'regular' air is already 75%-ish nitrogen. Not particularly useful for day-to-day driving, but nice for the track.
EDIT: Wait, am I making stuff up? I thought that was the main reason, but here's a link with more.
Old Nov 9, 2007 | 11:24 AM
nicknbecka's Avatar
nicknbecka
Good to know I'm not crazy
Old Nov 9, 2007 | 11:46 AM
windsorlove
makes sense about the nitrogen. and its funny because i just finished reading an article in Car & Driver about the new GTR and that is the reasoning they gave for nitrogen. by the way, its a good issue. i suggest that you guys pick it up. nissan gtr, porsche caymen gtr (tuner built) comparison between C63 AMG, RS4, and new M3, all around good read so far.
Old Nov 9, 2007 | 12:39 PM
MDK's Avatar
MDK
I can't wait to see what the tuners will do with this, sounds like a beast from the factory. Any mention of price?
Old Nov 9, 2007 | 12:46 PM
windsorlove
estimated price of $85,000. not too bad considering the performance. and according to the article, "Nissandevelopment team proudly claims it has made the ECU tamper-proof" we will see how long that lasts
Old Nov 9, 2007 | 03:46 PM
kenchan's Avatar
kenchan
hummm... V-spec is coming out in a few years, i read somewhere.
carid
Dec 28, 2025 04:11 AM
LifeAfterBeetle
R60/R61 Stock Problems/Issues
15
Mar 2, 2016 07:10 PM
theblackfalcon
Oct 11, 2015 09:49 AM
Olenska
Sep 21, 2015 12:36 PM
speltzer
Off-Topic :: Autos
Jun 10, 2004 08:59 PM
