Site Feedback Open forum for discussion of this site. Post your kudos or criticism so that we can continually improve service to the new MINI community.
Pulse broken?
Old Jun 30, 2003 | 02:57 PM
W3IWI
Mark -- lately when I hit PULSE (which I guess is a shortcut to bookmarkpulse.html), I get a brief flash of a new window opening up and disappearing, and then nothing, nil, zip, nada. Is PULSE broken?
Thanks, Tom
Old Jun 30, 2003 | 03:02 PM
Mark's Avatar
Mark
North American Motoring :: Founder
Tom,
Can you tell me what version operating system and browser you are using? Under Mozilla 1.0.1 (OSX), IE 5 (OSX), and IE 6 (Win98) it appears to be working well. Thanks!
Mark
Old Jun 30, 2003 | 03:07 PM
sram24's Avatar
sram24
>>Thanks, Tom
Do you have a pop-up blocker installed or enabled on your browser? This would cause the problem you are describing. I did a quick test in the "Opera" browser, and having the "Refuse Pop-Up Windows" option enabled caused the problem you described.
Old Jun 30, 2003 | 03:09 PM
FrogGuts's Avatar
FrogGuts
Tom,
If you are using IE, sometimes with popup windows you have to re-register the URLMON.DLL which is done by clicking START-RUN and type in the run box:
regsvr32 urlmon.dll
This might fix your problem.
Old Jul 5, 2003 | 09:03 PM
W3IWI
>>Tom,
Mark -- running latest IE6 under Win2K. I suspect that the problem may be a popup killer. Recently installed a high-speed DSL connection (replacing an earlier ISDN connection) and put in firewall software on the "main" machine.
Just checked my laptop (also connected to the LAN and DSL router) which has IE6 running under WinXP and it works fine. So the problem is somewhere in the "main" box's firewall. And the URLMON.DLL tip didn't solve the problem.
Thanks to all for the help -- Tom
Old Jul 5, 2003 | 09:25 PM
letsmotor's Avatar
letsmotor
I just installed Norton Internet Security 2003 and have the same problem with Pulse
Any ideas on how to fix this issue with pulse and firewall software?
Old Jul 7, 2003 | 10:28 AM
W3IWI
Mark -- I just found the problem here. I had recently added the newest Beta 2.0 version of the Google toolbar (http://toolbar.google.com). The toolbar has the ability to squelch popups. Turning off the popup killer solved the problem. Fortunately, the ON/OFF (or is it on/moron?) switch for the toolbar popup killer sits there at the top of IE6 and all I have to do is to toggle it OFF when using MCO.
Thanks for the help -- Tom
Old Jul 7, 2003 | 10:37 AM
Mark's Avatar
Mark
Tom,
Glad to hear that you determined the source of the problem. I doubt I would have figured that one out remotely but as I'll be installing the toolbar on one of my machines I'll be sure to remember this. Thanks!
Mark
Old Jul 7, 2003 | 10:40 AM
Mark's Avatar
Mark
I'm not familiar with the configuration of Norton Internet Security but my best recommendation is to look in the associated help files and search for pop-up blocking to see if you can allow some sites and not others. The reason this is causing problems is that the Pulse is launched like a pop-up ad would. The big difference is that you are choosing to do it versus the typical pop-up when you least expect it behavior we are all seeing today across the net. If you determine the configuration steps be sure to post it here so that others having similar problems can resolve them as well. Thanks!
Mark
Old Jul 7, 2003 | 06:36 PM
letsmotor's Avatar
letsmotor
I wish I could explain what I did, but Pulse all of the sudden works now . I really do not have a clue what I am doing
Old Jul 8, 2003 | 02:59 PM
W3IWI
>>Mark
Mark -- one nice thing about the Google toolbar: When you are logged in on one site and click "Allow Popups", the action applies only to that site. So the toolbar popup killer can prevent the X-10 ads and still allow Pulse to work.
Tom
elverado
Jan 18, 2022 02:51 AM
Fordgt4
Oct 10, 2015 10:42 AM
B1mm3r101
Oct 1, 2015 06:22 AM
daviday
Sep 25, 2015 01:31 AM
Tires, Wheels & Brakes
Sep 10, 2015 03:10 PM
