How to Remove Air From Cooling System?
Old Nov 6, 2007 | 02:20 PM
joshK's Avatar
joshK
I know on the R53's there was a valve by the thermostat, but how does one bleed any air from the cooling system in an R56?
Old Nov 9, 2007 | 11:56 AM
Bhatch's Avatar
Bhatch
Run the engine with the radiator cover off, it should burb the system. If there is not rad cap, i never looked. You have to fill it from the expansion tank, which is hassel. run the car with the expansion tank open it will purge it'self.
Old Nov 9, 2007 | 12:08 PM
th3118's Avatar
th3118
Coordinator :: Dynamic MiNi Collective
This diagram shows a vent screw (#8) in the thermostat housing:
http://www.realoem.com/bmw/showparts...31&hg=11&fg=35
Old Nov 11, 2007 | 07:18 AM
Robb's 07 Red MCS's Avatar
Robb's 07 Red MCS
Another way to do it is turn the temp control to max heat and run the fan on high. The air bubbles will pass through the heater core and vent through the system.
Hope this helps
Old Dec 19, 2007 | 06:08 PM
KMini's Avatar
KMini
You probably have worked it out but you access the bleed screw by the large connector on the thermostat housing. Put the fan and heat on HI.
I just had my rad replaced after a deer encounter but they failed to reconnect the top hose and my trip home ended in a cloud of steam... and I'm a bit steamed. Tomorrow will reveal if there was damage. no temp light but I think the sensor is in the thermostat housing and that would have been reading air. They apparently removed the hose to bleed air out of the heater. Regretting trading my 03 for an R56...
Old Dec 31, 2007 | 06:15 AM
djam43's Avatar
djam43
Originally Posted by Pard
Thanks for notifying us of the location of the vent screw, th3118. I found it on mine, but would like to know the actual procedure for bleeding the air from the system using this vent screw. Do I do it while the engine is running? Should I have the cap on the expansion tank or off? If anyone knows the exact procedure to do this correctly I'll be very grateful. Thanks in advance.
Definitely wouldnt remove that plug while the engine is running. I would run the engine for a few secs with the rad cap off then shut off and bleed . Repeat until no more air comes out. R56 engines heat up fast so be carefull
Kimolaoha
Jul 5, 2023 01:04 PM
Khai
Feb 6, 2017 09:24 AM
ki7hy
Aug 12, 2015 07:07 PM
Red Raven
Aug 11, 2015 04:48 AM
