Suspension Alignment questions for a stock MCS
I'm going to take my stock MCS JCW w/ stock sport suspension to the tire shop tommorow to get 215/40/17 tires fitted on 17x7.5 wheels. Well, I'm going to get an alignment along with the new tires. Now to improve handling and help alleviate understeer, should I deviate from the stock MCS alignment specs and tell the tech to add negative camber on the front wheels? How much negative camber do you guys recommend? I have to note that I don't want too much tire wear either as this car is my daily driver and I don't want to upgrade my suspension as this car is a lease.
What do you guys recommend I do?
I'd say long term you'll save more $$$ getting a stock alignment then adding a rear sway bar. It's a littlemoreupfront but you're tires will last longer and you'll have more significantincrease in handling that is easier to tune in your garage.
Interior/Exterior DEPO/Helix Projector Headlights Installed
Alkaidovich
Jan 30, 2021 01:35 AM
Minibeagle
Aug 13, 2015 10:00 AM
