R50/53 2006 MCS running rich
Old Oct 29, 2007 | 12:20 PM
HHFD633's Avatar
HHFD633
I have heard that the cooper s runs rich however for a while now i have noticed when i start my car it really smells bad very very rich. Also lots of carbon deposits on the exhaust so bad infact that it spits and i get it on the bumper.
Anyone have any ideas.
Old Oct 29, 2007 | 12:32 PM
grillhands's Avatar
grillhands
I think its time to get the ecu reflashed to fix your a/f mixture. It'll definately make the car run smoother.
Old Oct 29, 2007 | 03:19 PM
tech guy's Avatar
tech guy
your car will always run rich at start up. once it reaches proper temp the fuel system goes into closed loop and will make the proper adjustments between lean and rich according to throttle position and engine load.
Old Oct 29, 2007 | 06:03 PM
HHFD633's Avatar
HHFD633
so this is normal then. there is a lot of carbon coming out. spitting on the bumper.
Old Oct 29, 2007 | 06:04 PM
HHFD633's Avatar
HHFD633
dealer told me that there is not a update flash for my build date.
Old Oct 30, 2007 | 05:54 PM
NMgokart's Avatar
NMgokart
Same problem here; dealer reflashed mine (wiping out the GIAC flash) and no change. Smells like **** in the morning, tailpipes black after one drive to work and no help. I am beginning to believe (OK, I already believe) that the dealers have no clue how to fix these cars. If the ECU doesn't tell them what's wrong, their only solution is a reflash. Bull****! Why doesn't MINI train the service people to handle problems?
Old Oct 31, 2007 | 03:18 AM
Qksquirt's Avatar
Qksquirt
I've never noticed the smell, but yeah it does run rich most of the time. Never asked a the dealer, figured they know about as much as I do. I know automotive systems, all I need from them is the details.
Old Oct 31, 2007 | 06:59 AM
HHFD633's Avatar
HHFD633
anyone else?
Old Oct 31, 2007 | 08:18 AM
Aquasar's Avatar
Aquasar
Try searching for chadtoolio he is a tech at Mini of Charleston. He works on Brad Davis MINI racer.
Art
Old Oct 31, 2007 | 09:09 AM
Partsman's Avatar
Partsman
Legion_of_Doom
I had this same problem until I removed the pre-cat from the exhaust manifold, now my tail pipes just have very light coat of carbon. In fact, so light that you can barely see it on your finger after a swipe inside the pipe.
Old Oct 31, 2007 | 09:21 AM
HHFD633's Avatar
HHFD633
when u removed the precat did the exhuast get much loader
Old Oct 31, 2007 | 10:04 AM
Partsman's Avatar
Partsman
Legion_of_Doom
I didn't notice an increase in sound after removing it, but I did notice that the car felt different. It felt a lot better, definitely smoother running with a small increase in power.
The pre-cat is intended to decrease cold start emissions, after the cold start it's pretty much a restriction.
This is what's inside the pre-cat...
...it's amazing the car runs at all with this in there. Image courtesy of willy69.
Old Oct 31, 2007 | 12:59 PM
HHFD633's Avatar
HHFD633
does it pass emissions
Old Nov 1, 2007 | 05:36 AM
Partsman's Avatar
Partsman
Legion_of_Doom
I haven't had to get an actual emissions test done yet, but i'm sure it will be fine. The main/primary cat is still in place and that's the one that matters.
Old Nov 1, 2007 | 06:18 AM
Roeri's Avatar
Roeri
Where do I find this thing and how do I remove it?
Old Nov 1, 2007 | 07:07 AM
Partsman's Avatar
Partsman
Legion_of_Doom
In this pic, with the stock header on the bottom, the pre-cat is right after the flex joint...
...I had the whole section removed right up to the smooth bend. My exhaust guy put the O2 sensor bung right where the old one was.
Old Nov 1, 2007 | 08:43 AM
HHFD633's Avatar
HHFD633
and removing this made the carbon deposit get better?
Old Nov 1, 2007 | 08:50 AM
Partsman's Avatar
Partsman
Legion_of_Doom
From my post above...
Old Nov 1, 2007 | 10:05 AM
Partsman's Avatar
Partsman
Legion_of_Doom
Keep in mind, removing the pre-cat worked on my car, your results may vary.
Steeroidz
Aug 29, 2018 07:41 AM
keck.j
Aug 18, 2015 08:18 PM
Powershift
Aug 16, 2015 05:14 PM
minipopkart
Aug 13, 2015 05:22 AM
Lt. Dan
Aug 10, 2015 08:23 AM
