Navigation & Audio Audio Pop Quiz
Old Oct 26, 2007 | 10:25 PM
HotRodPilot's Avatar
HotRodPilot
Audio Pop Quiz
Ok, I just bought a Motorola/Sprint MOTORAZR2 v9m and I want to play the music on it through all the speakers in my June build 2005 Cooper S. Is there anything I can do, and if so, what?
Thanks in advance for answers
Edit, it has a mini USB connector on it.
Old Oct 26, 2007 | 11:34 PM
M3NTAL's Avatar
M3NTAL
Use the AUX in on the head-unit. Create a custom cable with the proper stereo plugs at each end. Not sure if the razr is a standard 3.5mm mini-jack or a micro jack.
Good luck
Old Oct 27, 2007 | 07:32 AM
HotRodPilot
There is no headphone jack. But is has bluetooth
Old Oct 27, 2007 | 09:07 AM
wildcrazy442000's Avatar
wildcrazy442000
Off thread, but how is your car doing after your booboo.
Old Oct 27, 2007 | 11:06 AM
rkw's Avatar
rkw
The users manual says "you can listen to your music through a wired headset with the Micro USB to 2.5mm headset jack adapter (included in the box with your phone)". You can connect that to the headunit's aux input (if you've installed it) but you'll need to connect between a 2.5mm jack and a 3.5mm jack.
You may be able to find a cable with 2.5mm plug at one end and 3.5mm plug at the other. Otherwise, you can use a 2.5mm to 3.5mm plug adapter (should be available at Radio Shack or a cell phone store), and a stereo cable with 3.5mm plugs at both ends.
Old Oct 27, 2007 | 11:43 AM
HotRodPilot
You must be thinking of the RAZR v3, no such cable was included in the box from Sprint, and that cable is nowhere to be found in the Sprint accessories
That'd work out perfect. I'm still googling to see if anyone makes that cable for the v9m
Old Oct 27, 2007 | 05:33 PM
cabrown's Avatar
cabrown
You can purchase that cable at a Sprint store, however. I purchased one for my SLVR (hate the phone, BTW, as all Motos) in order to use an FM transmitter I have. The FM transmitter notwithstanding, the sound from the phone just sounded awful.
Good luck with it, though. I'll try and remember to post a photo of the cable for you.
Old Oct 27, 2007 | 06:07 PM
rkw's Avatar
rkw
How is the sound on headphones? If the phone already sounds bad even with headphones, you are out of luck no matter what you connect it to. If it sounds decent on headphones, then aux input should work well. FM transmitters degrade the sound, often severely.
Old Oct 28, 2007 | 09:01 AM
cabrown's Avatar
cabrown
Let me go grab it and test it out. I'll also get that photo for you. I honestly couldn't comment on the audio quality via earphone/earbuds w/o revisiting it. I haven't used the device in almost a year.
Old Oct 31, 2007 | 04:51 AM
cabrown's Avatar
cabrown
Photos
Here are the photos of the device. I believe I actually purchased from the Motorola website, not a Sprint PCS store. I honestly don't recall any longer.
Take a look at the MotoStore in the Charger, Power, & More section for the "Mini USB Audio Adapter, Mono, 2.5mm jack."
scfiveo
Sep 27, 2019 02:27 PM
gar56
Nov 15, 2016 06:41 AM
patsum
11
Sep 30, 2015 02:20 PM
TifosinDel
Sep 28, 2015 10:45 AM
