SES Codes through On Board Computer
Old Oct 16, 2007 | 08:56 AM
Mustang7302's Avatar
Mustang7302
The wife ran through some standing water that was four or five inches deep which stalled the car. Apon start up there is a clacking noise after the event. Pushed the car to it's resting place and we out to examine the car when the weather let up. There are no obvious reasons for the rough idle/clanking, no water was sucked through the intake, no water in the oil, and there was no SES light till this morning.
I let the car sit over night and tryed starting it again. It seemed better after sitting but something is still wrong. After running for about 20 seconds, the RPMS went up to 1500RPM and back down followed by a SEL light. I have a feeling that one cyclender is not firing as there is a distinct raw fuel smell while was running.
I know there was a way to access OBD-II codes through on board computer, but I am having a hard time finding the documenation. If someone would be kind enough to link it for me, I would greatly appreciate it.
Old Oct 16, 2007 | 06:07 PM
tech guy's Avatar
tech guy
u need a diagram of the OBD2 connector pin out. i can get it for you tomorrow at work at like 12:30 if you can wait. you'll need to jump 2 points with a paper clip then turn the ignition on, engine off. count how many times the check engine light flashes. it will flash each code 3 times. so say it flashes 3 times, followed by a short pause, and then 4 more times. thats code 34. then it will repeat two more times and go on to the next if there are multiple codes. i've never had to jump the connector on a mini but this procedure works for most cars.
Old Oct 16, 2007 | 07:12 PM
Mustang7302
The sooner the better, the car will likely be headed to the dealer tomorrow if I can't figure out what is going on.
Thank you for your help.
Old Oct 16, 2007 | 07:13 PM
MRmidge's Avatar
MRmidge
50-80 bucks buys you an OBD2 scanner that will nicely and easily tell you whats going on. I can even check the emissions readings with the one i have. Worth the money if you own vehicles from 96' and on.
Old Oct 16, 2007 | 08:25 PM
chpsk8's Avatar
chpsk8
Dude buy a scanner. With today's cars a scanner is just a tool that is a must have. I've bought wrenches that cost more than a scanner, so there really aren't any excuses to not have one.
An contrary to internet lore... not all Autozones will read the codes for free. They looked at me like I was crazy the first place I asked... then I crossed to a different state and they flat out said no... so I bought my own scanner.
Oh.. good luck btw. I hope it all works out. Probably just needs to dry out
Old Oct 17, 2007 | 06:00 AM
techtipz's Avatar
techtipz
Sounds like you may need an engine. have you seen any oil or any thing under the vehicle? How long does the car run for before stalling?
Old Oct 17, 2007 | 06:33 AM
Mustang7302
MRmidge and chpsk8, you're right. I dropped by auto zone this morning and bought a $60 scan tool. Hooked it up to my car and it said the cat is not with in threshold (duh, there isn't any) and there was an issue with the knock sensor. Hooked it up to the wife's MINI, "misfire on cyclender 1."
Back off to auto zone for new plugs.
BTW, I did check last night, there was no indication of water in the spark plug wells.
Old Oct 17, 2007 | 03:03 PM
Mustang7302
Replaced the plugs and the ignition coil to have the same problem and error code. Car was put on a flat bed and is at Mini pending diagnosis.
Old Oct 17, 2007 | 03:39 PM
tech guy's Avatar
tech guy
could be a bad ecm.
molala
Oct 2, 2015 01:53 PM
Gen1Parts
Sep 7, 2015 03:50 PM
Gen1Parts
Sep 7, 2015 01:37 PM
mimaal
Sep 4, 2015 09:09 AM
