Plastic Hubcentric Rings?
I just got a set of wheels from WheelMax (fast and cheap, and the wheels look great!), and it came with the plastic hubcentric rings. How necessary is it I get the metal ones. I don't do autocross, and if I do anything like that, it will not be alot. Just normal driving, and twisties when I can.....
I have melted plastic rings with track use but for street or autocross it should be no problem.
The melt issue is something I hadn't considered before but is not the only issue you "should" consider.
I have 2 sets of wheels & tires, 1 w/ plastic, the other w/ metal. One of my plastic ones got mushroomed when a tire jockey put my lugs on unevenly then forced the wheel the rest of the way on w/ impact wrench.
I didn't know until I tried to take that tire off to change brake pads! Man, was it ever stuck. Made me mutter words I normally don't admit using.
Some tire places don't let customers in their shop area, find one that does!
Heh, heh... I solved that problem... I don't let tire places TOUCH my MINI... I take them wheels, they mount tires, I inspect the wheels (inside and out) to make sure they didn't destroy them, I take wheels back home and install. They say "but we'll mount them on the car for the same price" and I say "I know - but no thank you!"
mount the tires for me. then drive back and mount it on my car.
I've never melted mine - AX, track, and daily driving... BUT, Dr. Mike, on the other hand, literally incinerated a set at the track. Being Dr. Mike, he machined his own aluminum set on a lathe from some spare material laying around. He's never had a problem since!
Track lapping?
Drag racing?
Autocross?
Pro Solo racing?
It's during heavy braking use that enough heat is generated to melt plastic.
I never melt plastic rings unless it's on a track doing lapping or driving school. I wouldn't go on a track with no rings if the wheels were supposed to have rings.
If you use your brakes hard enough and they don't cool down enough you risk heat problems-
I've melted heavy plastic rings- make them look totally distorted and stuck to the hub.
Boiled brake fluid
Cracked cross drilled rotors
Brunt/discolored brake caliper paint- from bright red to black brown.
Fastest in what measured way?
Track lapping?
Drag racing?
Autocross?
Pro Solo racing?
Boiled brake fluid
Track lapping?
Drag racing?
Autocross?
Pro Solo racing?
Boiled brake fluid
You sir, know how to have fun.
RobbyD
Jan 29, 2019 01:22 PM
EVMini
Sep 28, 2015 10:20 AM
Nicefeet
Sep 24, 2015 06:53 PM
not fair!
