R50/53 help taking a panel off ASAP!!!
Old Oct 3, 2007 | 11:08 AM
pimpedout97x's Avatar
pimpedout97x
the very very back pillar behind the back side windows, with the airbag behind it...does it just pull off? is the bag going to activate or anything? need to remove the rear seat belt for my wall project. someone let me know so i can go back in the garage and continue!
ps, i also am going to cover those and the headliner in a light gray suede
Old Oct 3, 2007 | 11:10 AM
goldcountrymini's Avatar
goldcountrymini
Are you talking about the front windows or rear windows (rear seats)? Have you removed the plastic panels and rear seats?
Old Oct 3, 2007 | 11:13 AM
pimpedout97x
rear seats are out, rear panels are out, its the little pillar in the back right next to the boot (on both sides) right under the headliner
Old Oct 3, 2007 | 11:16 AM
pimpedout97x
where the back seat belts come out of at the top
Old Oct 3, 2007 | 11:17 AM
goldcountrymini
Got it... Sorry, I have not removed those before. I don't think your airbag will deploy with those pillars. I know the front pillars are a little more delicate. Do the rear pillars you're trying to remove have any screws/bolts? I think they just pop off...
Anyone else know?
Old Oct 3, 2007 | 11:19 AM
MiNi_MaC's Avatar
MiNi_MaC
I dont know about the rear pillar, but the front ones, are disposable, meaning, if you take them off you have to get new ones.. according to bently manual
pimpedout97x
i got it pretty loose now, it was 4 clips, but it looks like somethings connected to the bag or something, and im just scared im going to make it deploy. how do you disconnect them? i dont even need them connected, theres going to be no more rear seats... lol
Old Oct 3, 2007 | 11:20 AM
pimpedout97x
are you serious!?!?! i wanna cover them in suede, theres gotta be a way to put them back on without getting new ones
Old Oct 3, 2007 | 11:21 AM
goldcountrymini
Disconnecting the airbag... There is a clip you'll have to lift to remove the connection. A flat head screw driver should allow you to lift up gently and then pull apart...
Old Oct 3, 2007 | 11:22 AM
goldcountrymini
I removed my front pillar and re-installed with no problems during a radar install...
pimpedout97x
is the clip behind the rear panels, i should see it pretty easy? will it affect anything else if i leave it disconnected?
Old Oct 3, 2007 | 11:26 AM
pimpedout97x
well ill be outside, ill post in a few how it goes, or if i break something LOL
goldcountrymini
If you leave it disconnected and turn on the car, the airbag light will come on... If you do that and then re-connect, the airbag light will stay on. I suggest you leave it connected. I dont' know if there is away to trick it to think it's connected.
Good luck.
Old Oct 3, 2007 | 01:40 PM
kenchan's Avatar
kenchan
i think you can use a 3ohm resistor and trick it. youll want to
wire up a 2A fuse on it too.
dont quote me on it though as i haven't needed to trick the SRS on the MINI
yet.
Old Oct 3, 2007 | 01:54 PM
goldcountrymini
You've gotta love the MINI community & NAM.
That sounds like it would work Ken... I'd check with an auto shop though to make sure.. Car audio shop or something like that.
Old Oct 3, 2007 | 02:01 PM
kenchan's Avatar
kenchan
or you might be able to find a plug and play steering boss (hub)
maker out of Japan for our MINI's that includes the resistor..and
get the values from that.
most steering hubs sold in japan come with a plug an play harness.
Old Oct 3, 2007 | 02:22 PM
k-huevo's Avatar
k-huevo
There is a strap attached to a clip that is a one time use only, meaning the clip can only go in once. The strap keeps the C pillar from knocking you in the head if the air curtain deploys. I removed my seat belt hardware without cutting the strap or mangling the clip; the C pillar just hung to the side. No need to disconnect any type of wire connector.
Old Oct 3, 2007 | 07:41 PM
pimpedout97x
i got the belt through, but im covering it in suede. i guess i can do it with it hanging there LOL
Old Oct 3, 2007 | 08:20 PM
JAB 67's Avatar
JAB 67
When I removed the c-pillar cover to run my XM antenna, I was not able to completely reinstall it; as a previous poster has written, some aspect of it is one-time use only.
eatsleepautox
Oct 30, 2015 06:46 AM
artguy
R58 :: Coupé Talk (2012+)
Aug 30, 2015 07:56 PM
gknorr
Aug 24, 2015 06:39 PM
chicohuahua
22
Aug 20, 2015 11:17 AM
Aug 19, 2015 09:12 AM
