Navigation & Audio XM solutions
Old Oct 2, 2007 | 06:05 AM
spfdhed's Avatar
spfdhed
XM solutions
I am a long time XM subscriber, so when I pick up my MINI next week, I plan on doing the aftermarket unit until the "merger". Anyway, could some of you who are using XM show some pictures of the the units and their mounting. I want to get something that could fit at the bottom of the front stack and would like to know what options are available. Also, those of you who "hardwired" their XM units, did you actually hardwire the power line or just add a hidden extra cig plug to plug the XM receiver into? If you hardwired, how did you do it? Thanks for any/all help.
Old Oct 2, 2007 | 06:33 AM
SandiePepper's Avatar
SandiePepper
No pictures, used Blitz Safe and it's throught the radio
Old Oct 2, 2007 | 07:04 AM
cadfael_tex's Avatar
cadfael_tex
I don't have an R56 but I have blitzsafe as well and it works really well through my head unit. You might give tom@eas.com a buzz and see if the system is compatible with the R56 because it is a nice elegant hardwire solution.
Old Oct 2, 2007 | 10:49 AM
Modnar's Avatar
Modnar
Thread hijack!
So, what is the deal w/ the merger? Is it going to happen, and if/when it does, does anyone know if:
  • the lifetime SIRIUS subscription will be honored by the merged company?
  • you'll be able to get all of the XM channels on your SIRIUS enabled factory head unit?
I'm already thinking about getting 2/3rds of the audio package (HD+HiFi), but if I can get NHL games (currently on XM) that might be worth the extra moola to go for the whole package.
Old Oct 2, 2007 | 02:27 PM
spfdhed's Avatar
spfdhed
I should have been more specific. I am talking about the R56 only-no blitzsafe solution now and probably never. I plan on plugging the audio into the aux in and want to know about how people are mounting the XM units. Thanks.
Old Oct 2, 2007 | 04:29 PM
wolf617's Avatar
wolf617
I'm using the Aux input with an XM Roady XT. I mounted the XM unit and a Garmin Nuvi 200 on a ProClip mount. I bought an adapter that has 2 cigarette lighter sockets and plugged that into the cig. lighter socket.
I ran an ebay-sourced SMB wire (actually 2 hooked together) to the sat. antenna under the passenger seat. You can search for another thread on this antenna hookup.
I ran the wire up next to the side of the seat and tucked it under the plastic of the console.
The sound quality is very good. At first I was disappointed with the volume level available through the stereo. I then realized that you can adjust the volume through the Roady. This was something that wasn't possible with the old SkyFi I have in my truck.
Old Oct 2, 2007 | 09:43 PM
kukaepe's Avatar
kukaepe
Sportscaster
I installed a Sportscaster in the cubby ahead of the cup holders. Fits well, tied into the "shark fin" on the roof using SMB male by female cable on the EBAY tied into the connector under the passenger seat. Tied into the fuse box with a "add a circuit" fuse adaptor for power and an voltage converter from xmfanstore.com. Sorry photo isn't any better, will try to send more.
Old Oct 8, 2007 | 04:28 AM
glangford's Avatar
glangford
I don't have a picture, but I use a roady XT and the aux port. It sits just nicely in the passenger cup holder angled toward me. I really wish blitzsafe would come up with an aftermarket solution.
Old Oct 14, 2007 | 08:28 AM
Paul's Avatar
Paul
So the Sirius antenna works for your XM? Very cool! Who did you buy the connector from on ebay?
Old Oct 15, 2007 | 06:11 PM
kukaepe's Avatar
kukaepe
Search eBay Motors for SMB connector cable, it'll come up I think. If you can't find it by searching, I'll dig up my records.
Old Oct 15, 2007 | 10:16 PM
DyeLooper's Avatar
DyeLooper
I just bought the add a circuit. Question, peeps say to put into fuse 21? Does this power on the unit when the accessories is on also? I'm assuming turns it off when the car is off?
http://cgi.ebay.com/SMB-m-to-SMB-f-e...ayphotohosting
Old Oct 16, 2007 | 05:16 PM
tbonecopper's Avatar
tbonecopper
Can someone post a picture, of their setup, where they have added an external radio, and tapped into the antenna wire under the passenger seat that routes to the shark fin antenna? I'd like to see how you've run the antenna extension cable...
I'm torn between tapping into the wire with a secondary radio, or just using the XM Radio app on my treo with the auxillary input.
Old Oct 16, 2007 | 05:32 PM
4xAAA's Avatar
4xAAA
Ditto that for me. I used two-sided tape and secured the unit to the underside of the stack. I used the mount for the Sportscaster by removing the suction cups. I also passed the aux plug thru one of the holes for the suction cups. Gave the unit a little more stability.
I have had it fall twice. Both were very hot days and the adhesive just gave up.
Still looking for a better way to secure it, but it sits very neat while attached. Solid sound, too.
Old Oct 30, 2007 | 01:38 PM
<MINI>'s Avatar
<MINI>
I bought 2 SMB cables from the guy on Ebay for about $9 each. This will get you from under the seat to the stack area easily. One is a bit short. I plugged into the connector under the seat and ran the wire towards the center console, under the seat rail. From here, I ran it under the console by just pushing it under the edge. No dissassembly required. This will get you under the dash to continue to your location.
Old Oct 30, 2007 | 04:56 PM
DyeLooper's Avatar
DyeLooper
Ditto to Above!
rikaro
Nov 24, 2015 02:05 PM
Suspension Products
Oct 1, 2015 11:53 AM
bradstyle
Oct 1, 2015 11:15 AM
Emnotek
Sep 29, 2015 07:37 AM
