R56 Acceleration Pause
Old Sep 25, 2007 | 06:44 AM
liafia's Avatar
liafia
Acceleration Pause
Does the break in period affect the pause in acceleration? Specifically, the hesitation in acceleration between the time you put your foot down and the time it takes to take off. Is that just my MINI? Is it also in the S? It bugs me when I want to pull out into traffic...and can make for a jerky take off.
Old Sep 25, 2007 | 07:09 AM
4xAAA's Avatar
4xAAA
Response time can be cut with the Sport Button. It is already a habit to push the button. I press start, hit the sport button, and grab the shifter.
I would also say that Percy adjust to my driving habits. After the wife drives for a few days Percy drives a bit different. Couple of starts and stops and it is back to my style.
Old Sep 25, 2007 | 07:15 AM
rockridge's Avatar
rockridge
I have not noticed this.
Old Sep 25, 2007 | 07:19 AM
Nightsky's Avatar
Nightsky
I haven't noticed it either, just 500 miles on Toria.
Old Sep 25, 2007 | 07:26 AM
jw34's Avatar
jw34
I notice it a little with the auto trans. But as mentioned before, let the Sport button be your friend.
Old Sep 25, 2007 | 09:03 AM
glnr13's Avatar
glnr13
it could be the DSC kicking on. lots of 1st gen MINI's experienced this hesitation especially when taking off to make a left thru an intersection.
Old Sep 25, 2007 | 09:27 AM
r56mini's Avatar
r56mini
Leave the sport button on and it will make a difference when taking off.
However, I notice a brief hesitation at 3000 rpm when I am accelerating...especially in 2nd and 3rd gears.
Old Sep 25, 2007 | 01:06 PM
Bhatch's Avatar
Bhatch
it is caused by buy the throttle by wire system. This was my fist concern on my test drive, the sport button fixed it. If this sport button was not there i would never had gotten the car. That throttle delay is killer
just press the sprot button and it will go away.
Old Sep 25, 2007 | 02:20 PM
MotorMouth's Avatar
MotorMouth
I haven't felt it myself but all the dynos show a dip in torque right about there.
OP - you have stick or auto trans?
Old Sep 25, 2007 | 04:52 PM
Msteadman's Avatar
Msteadman
+1. It's ESPECIALLY pronounced with the auto trans but the sport button eliminates it. I'm pretty sure (on my MINI at least) that it's linked to the fact that with the sport button off the auto trans starts off in 2nd gear while with the sport button on it launches in 1st.
Old Sep 25, 2007 | 07:20 PM
amazonracer's Avatar
amazonracer
My MCS Auto has done it for 3,300 miles. Getting use to it now.
Old Sep 25, 2007 | 08:03 PM
liafia's Avatar
liafia
Exactly!! Left turn into an intersection!
Old Sep 25, 2007 | 08:05 PM
liafia's Avatar
liafia
Ahh, that makes sense. Does the sport button eat up lots more gas?
Old Sep 25, 2007 | 08:08 PM
scott48's Avatar
scott48
There's a dip in the torque and hp curve at like 3000rpm cause of the ecu, that's the only thing I've noticed....we definitely need an ecu tune to get rid of that dip.
Old Sep 25, 2007 | 08:10 PM
r56mini's Avatar
r56mini
I am sure it does but not much obviously as I consistently get 32.X mpg mixed aggressive freeway merging almost every time. Only DSC does that not ASC? I think the device in action when taking off is ASC.
Old Sep 25, 2007 | 08:42 PM
scabpicker's Avatar
scabpicker
I personally only notice the power dip in 2nd and 3rd gears, and only when the car is cold. When accelerating in higher gears on the freeway, either it does not happen, or the higher gearing is muting the output of the engine where my butt can't tell anymore.
Old Sep 25, 2007 | 08:44 PM
Msteadman's Avatar
Msteadman
Again this is with the automatic, but I definitely recognize a marked decrease in fuel economy with the sport button on - 3-5mpg on average.
Old Sep 25, 2007 | 09:01 PM
amazingrando's Avatar
amazingrando
Auto on Sport Button guy
I don't believe that the sport button alters fuel econemy, I get 32-38mpg in my S. I just push the start button and go...the sport button comes on automaticly with my mod
Old Sep 25, 2007 | 09:05 PM
porkchop's Avatar
porkchop
I know the hesitation of which you speak. It was bad, but its been going away; I'm now up to about 880 miles on the odo. It could also be that I'm getting more used to the throttle...
Old Sep 26, 2007 | 06:37 AM
Bhatch's Avatar
Bhatch
It is not a drop in power, it is a delay on the throttle. It is only like 1/2 a second or less without the sport button on..but it is clearly there if you shift quick.
Old Sep 26, 2007 | 06:53 AM
Beebe's Avatar
Beebe
This is so strange, I really noticed this on the test drive (MCSa) and I actually wondered if my foot was positioned wrong on the gas pedal or something weird like that!!! I'm picking up my car in a few hours and I will be on the lookout for this.
Old Sep 26, 2007 | 07:03 AM
korby's Avatar
korby
I've had the pause occasionally at all different speeds ,almost like the the computer gets confused or something .It's a fraction of a second and has never put me in danger .
Old Sep 26, 2007 | 08:21 AM
liafia's Avatar
liafia
wore my heavy boots yesterday....cleared it right up
Old Sep 26, 2007 | 12:39 PM
familiarstranger's Avatar
familiarstranger
its not there if you give it the slightest bit of gas right before the green.
randeez
Oct 5, 2015 09:23 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
thadscottmoore
Sep 25, 2015 10:07 AM
gzaos
Sep 14, 2015 04:21 AM
HogWldFLTR
Sep 8, 2015 05:25 AM
