Navigation & Audio Removing head unit
Old Jun 19, 2003 | 07:50 PM
silver-mini-s's Avatar
silver-mini-s
Can anyone point me to instruction on how to remove the H/K head unit to install the Aux port. I just got the aux cable and I need to remove the unit to get behind it...
JT
Old Jun 19, 2003 | 09:12 PM
silver-mini-s
It took me 2 min. to install the AUX cable behind the H/K head unit. all I had to do was follow these instructions...
----Removal of the knee bolster is required to gain access to the upper torx screw on the driver's side dash downtube, or to install the European [driver's side] parcel shelf.
The knee bolster is anchored at the top and hinged on the bottom.
To remove it:
Grab the top edge with both hands.
Pull down sharply keeping the pressure toward the direction of the door in order to prevent the bolster from scratching the downtube when it comes free.
Rotate downward and pull out.
After I removed the Knee Bolster I reached behind felt the back of the H/K unit. After finding the right spot I just pluged the cable in and I was done!!!
I didn't want to install the jack in the glove box because I bought a mount kit for my Ipaq. So I ran the cable to the bottom of all the switch panel and screw it in there. This kit was a dealer purchase for $40. Hope this helps some of you...I'm going to go and download some music on my Ipaq.... :smile: later!!
null
Old Jun 19, 2003 | 09:14 PM
EliteCooperS's Avatar
EliteCooperS
any pics?? how is it working... etc... do u have to remove parcel shelf if u want to run it through glove box? i am gettin mine in about 2 days or so
Old Jun 20, 2003 | 02:36 PM
EliteCooperS
i got the aux port just 5 mins ago in the mail... the installation looks very very difficult at first glimpse, im gonna try to tackle it later in the day or tomorrow. anyone have a how-to?? also the input is just one hole, so how do we hook our mp3 players into it??
Old Jun 20, 2003 | 04:19 PM
silver-mini-s
Like I said in my previous post, you do not need to take the head unit apart! All you have to do is follow these instructions…
Removal of the knee bolster.
To remove it:
Grab the top edge “where it has a half moon cut because of the steering column” with both hands.
Pull down sharply keeping the pressure toward the direction of the door in order to prevent the bolster from scratching the down tube when it comes free.
Look at where your steering column is coming down and grab the top half round part of the knee bolster. The knee bolster is where your knees touch when your seat is too far forward. Grab the top and pull on it, it will release from the dash. After it releases you can swing it down because it is on hinges. You do not need to remove it. Now you have access to the back of the unit. You will not be able to see the back of the head unit but you will be able to feel it. Look at the instruction that came with the AUX cable and with feel try to plug the cable in to the back of the unit. It took me 2 tries to find the hole it plugs into. This was a lot easier then removing the head unit and it only took 2 minutes to do. No screw removal necessary!!
The hole on the other side of the AUX cable is the same kind of hole a headphone jack plugs into. Got to your nearest radio shack or stereo store and purchase male to male wire to fit one end to the AUX and the other to an Ipaq, Ipod, laptop…
Old Jul 15, 2003 | 04:05 AM
onetwelve-112's Avatar
onetwelve-112
HELP ME!!!!!
lol...i still cant remove the knee bolster!!! ive pulled pushed yanked at the damn thing but it wont budge. I had a look under-neath it and it does seem to be on hinges but it still will not budge when i pull on it!! Any more ideas?
Cheers
112
Old Jul 15, 2003 | 05:05 AM
onetwelve-112
:smile: :smile: :smile: :smile: :smile:
wohoooo just irritated myself into going and being violent with my car and i did it!!!! ive pulled the knee bolster clean off! cant wait to get home and fit the CD player now!!
cheers for all your help people!
Old Jul 16, 2003 | 01:14 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
for replacing the headunit see
http://www.tech-esq.com/mini/Hifi.htm
Old Jul 16, 2003 | 02:39 AM
onetwelve-112
All done and dusted now...had to order in a connecter for cables as BMW haev decided to change the generic one to a rather strange one! but everything is in place and i will have my music back in 3 days time! thanks for all your help guys!
jnrjr79
Navigation/Audio
18
Sep 18, 2015 05:51 AM
yashmack
Aug 15, 2015 03:11 PM
wind715
Aug 11, 2015 07:56 AM
veevsato
Aug 5, 2015 04:42 AM
