Tire advice needed
The diameter of replacement tires should be within ±3% of the factory specification. Running 205/60-16 tires would make your speedometer read 5.1% too slow.
The most common plus size replacement is 205/50-16.
205/60-16 fits rims 5.5-7.5" wide and stands 25.7" tall so tire diameter is about 1.4" taller than stock which may be too tall for daily use and with most suspensions and loads. With people in the rear seat, it would likely scrape against the plastic liners on the tops of the wheel wells and maybe in the front against the arches when turning. Speedo and odometer would be off.
Usually it is safer to try to be closer to the stock tire diameter of about 24.3".
So when shopping if you see tire diameters of about 24.6 to 25" that's about the limit under normal use.
205/55-16 will give you quite a good selection of tires that are very similar to those you can find in 205/60-16 and will have a tire diameter of 24.9" which is taller than stock but it will work.
If you want the most accurate speedometer readings then the closer you can get to stock tire height the better and 205/50-16 will be pretty good.
Tire diameter is 24.1".
Why do you ask about 205/60-16? It is not a tire size that is suggested nor mentioned much at NAM. Was there a winter tire that you were interested in?
he might be worried about the rear strut bottom scraping the car
wash rails?
i would probably run 195/60/16's if i was to get winters.
wash rails?
Colt45Magnus
Sep 7, 2015 10:47 PM
Rennfahrer555
Aug 13, 2015 09:07 AM
minipopkart
Aug 13, 2015 05:22 AM
