Suspension rear tire cupping ?
Old Sep 3, 2007 | 07:48 AM
tools's Avatar
tools
rear tire cupping ?
My left rear tire is showing some cupping. this wheel seems to have a slight more angle to it than the right one. Any suggestions as to what could be the problem?
Old Sep 3, 2007 | 07:59 AM
apexer's Avatar
apexer
Hopefully just an alignment problem and nothing is bent. You'll not know until you get a 4 wheel alignment.
Old Sep 3, 2007 | 09:41 AM
tools's Avatar
tools
I had an alignment just after installing new struts an knothing was said about any problems. This started just after that.
Old Sep 4, 2007 | 10:40 AM
tools's Avatar
tools
Went back to where I got alignment and had it checked again. They found that the rear camber was off and made adjustment. Now we will see if that solves the problem. Follow up to come soon.
Old Sep 4, 2007 | 01:58 PM
Crashton's Avatar
Crashton
IMO cupping isn't a result of bad camber. Wear on the inner or outer edge is. Cupping can be caused by bad balance & or by not rotating the tires. I don't know why, but it has been my experience that rear tires on a FWD cars will cup if not rotated. It's good you got an alignment, but I think your cupped tires are going to stay cupped.
Old Sep 5, 2007 | 08:28 AM
tools's Avatar
tools
I rotate my tires every 6,000 miles.
Old Sep 5, 2007 | 08:32 AM
Eric_Rowland's Avatar
Eric_Rowland
Cupping tends to be caused by worn shocks, no?
Old Sep 5, 2007 | 10:29 AM
Wake|MCS's Avatar
Wake|MCS
What exactly is cupping?
Old Sep 5, 2007 | 01:25 PM
tools's Avatar
tools
Brand new struts. Koni FSD
Old Sep 5, 2007 | 01:31 PM
tools's Avatar
tools
Cupping is where your tires get cups in the treads, uneven wear. And when you rotate them the tires will roar like the tires on some of the big 4 Wheelers
and the old snow tires
Old Sep 5, 2007 | 01:59 PM
Crashton's Avatar
Crashton
Heck I don't know what to tell you. Every 6,000 seems often enough to me. I'm puzzled.
Old Sep 11, 2007 | 05:10 AM
tools's Avatar
tools
I found out the problem. The Adjustment bolts for the rear camber adjustment were loose ( they forgot to tighten them on last alignment) which caused the suspention to flex ( the camber would go in and out as you drove ) The person that did the aligment the first time no longer works there (they fired him for screwing up other peoples cars ) It cost them alot of money in new tires and adjustments.
Old Sep 11, 2007 | 05:21 AM
BlimeyCabrio's Avatar
BlimeyCabrio
Wow.... glad you found it, but sorry you got a crappy alignment....
Now I'm sweating as I have an alignment scheduled in an hour...
Old Sep 11, 2007 | 05:38 AM
kenchan's Avatar
kenchan
i was gonna say... show us some picts... but then yah, loose sus parts can
cause 'cupping.' terrible mistake by some newb at the shop.
Old Sep 11, 2007 | 09:29 AM
Mr.GBMiniGirl's Avatar
Mr.GBMiniGirl
mine also started cupping. When i rotated and did another alignment the rear right toe was out. I must've hit something.
Old Sep 11, 2007 | 10:55 AM
cooldaddy's Avatar
cooldaddy
does anyone have a pic or drawing of the rear camber adjustment bolt location? I want to see if I can dial out any of the excess camber on my lowered car - I realize the adjustment is very limited and most likely already set to its maximum 'positive' setting and I should go with some aftermarket control arms but still...
Old Sep 11, 2007 | 06:37 PM
chuckt's Avatar
chuckt
Here:
Old Sep 11, 2007 | 07:11 PM
cooldaddy's Avatar
cooldaddy
that's too funny, that's my own car
Originally Posted by chuckt
Here:
W0TM8
Dec 19, 2019 07:50 AM
kazyn
Oct 25, 2019 02:34 PM
Toolman
Jan 20, 2016 06:50 AM
caiken
Aug 27, 2015 06:55 AM
