Navigation & Audio secret compartment size?
Old Aug 23, 2007 | 03:46 PM
darigaaz12's Avatar
darigaaz12
Is it standard DIN size like after market radios?
Old Aug 27, 2007 | 04:16 PM
a96bimmerm3's Avatar
a96bimmerm3
tiny bit larger, someone put a pioneer head unit in there already.
Old Aug 28, 2007 | 07:24 PM
FortyTwo's Avatar
FortyTwo
https://www.northamericanmotoring.co...90#post1717590
Old Nov 28, 2010 | 02:10 PM
wuttuptae's Avatar
wuttuptae
Old thread, I know, but I can't find this info. anywhere (maybe I'm not good at using the search tool). Does someone know the actual dimensions of the secret compartment (preferably without the sleeve)?
A single-DIN is supposedly 180mm x 50mm (7" by 2" in US, which is 178mm x 51mm) with varying depth. I'm looking at Mini-ATX/Mini-ITX cases, and it'd be a great help to know what would fit -- including depth.
Old Nov 29, 2010 | 05:58 AM
schatzy62's Avatar
schatzy62
Check out this thread there is no actual dimension listed but the standard but what i can tell you is that a Mac Mini sized case will fit in the secret compartment. The AOpen used in my installation is exactly the same size as a Mac Mini.
https://www.northamericanmotoring.co...-upgrades.html
Old Nov 29, 2010 | 10:03 AM
wuttuptae's Avatar
wuttuptae
Thanks, schatzy. You and lacning were the main catalysts for even thinking about pursuing this, so I've already drooled over your install many times.
It looks like AOpen's mini pc case is 166(W) x 48(H) x 157(D) mm, so at least 157mm deep is good to know. Did you leave the factory sleeve/molding in place for the secret compartment? Or am I seeing it wrong?
*EDIT: I looked up the specs on the original/1st gen Mac Mini and it is: 165(W) x 51(H) x 165(D) mm. So, it's a pretty close fit to a single-DIN.
Doc Pain
Oct 28, 2015 07:09 PM
OldElvis
Tires, Wheels, & Brakes
Oct 1, 2015 06:21 AM
simo711
Oct 1, 2015 05:36 AM
WhinyR53
Sep 30, 2015 07:36 AM
BossyR56
Sep 28, 2015 11:33 AM
