04 MCS Crank Grind Specs?
Old Aug 20, 2007 | 04:41 AM
sampsonm's Avatar
sampsonm
Does anyone know the crankshaft grind specs for a 04 MCS? I spun the #1 rod bearing in my 04 MCS. The shop I gave the crank to be turned called AERA but the specs they gave them do not match the crank. It looks like I can use 10 thousands bearnings, if I can get the correct grind specs. If I can not get the specs I will have to get a new crank.
Old Aug 20, 2007 | 05:10 PM
herbie hind's Avatar
herbie hind
if you can't get them from your local dealer; try p.m.ing mario kart i think he may have done his crank when he lost #1 . then try endyn .
Old Aug 20, 2007 | 05:38 PM
herbie hind
end float is ; .090 to .240 mm
bigend journal is 43.992 to 44.008 mm .
main journal ; 47.922 to 48.008 mm .
big end clearance' .023 to .067 mm .
main clearance .020 to .058 mm
bently is good but the haynes has all the rebuild stuff . luck .
Old Aug 21, 2007 | 05:41 AM
sampsonm's Avatar
sampsonm
rikaro
Aug 7, 2021 02:33 PM
oeklm
Feb 17, 2016 01:00 PM
Flying Sq
Aug 31, 2015 06:42 AM
Camaro108
Aug 25, 2015 02:44 PM
keck.j
Aug 18, 2015 08:18 PM
