Conticomfortkit
Old Aug 15, 2007 | 10:04 AM
naffets's Avatar
naffets
Conticomfortkit
Has anone tried this yet?
Seems kind of pricey
http://www.tirerack.com/accessories/...tkit/index.jsp
The ContiComfortKit combines a powerful, high-volume, 12-volt air compressor, integral pressure gauge and a latex liquid tire sealant packaged in a compact, lightweight unit that's easy to store in the vehicle. (Kit is 9.5"W x 7"H x 3.75"D.) This product's sealant may interfere with the tire pressure monitoring sensors on vehicles with direct TPMS, possibly leading to error prompts and incorrect pressure readings. Use of this product on direct TPMS vehicles could also result in damage to the tire pressure sensor inside the wheel. Please contact your sales specialist at The Tire Rack for more information.
The ContiComfortKit can also be used as a stand-alone compressor without the sealant activated. When used in this mode, the ContiComfortKit can be used for periodic tire maintenance to compensate for tire pressure losses over time or due to changes in ambient temperature. And in the case of a very slow leak, the ContiComfortKit can restore sufficient pressure without requiring the use of sealant to drive the vehicle to a nearby tire repair facility.
Old Aug 15, 2007 | 10:09 AM
Eric_Rowland's Avatar
Eric_Rowland
https://www.northamericanmotoring.co...archid=3134828
Old Aug 15, 2007 | 11:26 AM
kapps's Avatar
kapps
I carry one. Never used it for a puncture but it fills up a low tire pretty quick if I'm not at home.
Old Aug 15, 2007 | 02:49 PM
Dan00Hawk's Avatar
Dan00Hawk
Less expensive alternative that will essentially serve the same purpose:
https://www.northamericanmotoring.co...ighlight=slime
Old Aug 15, 2007 | 03:32 PM
naffets's Avatar
naffets
Yes I know about the slime one but it seems pretty cheap and cheaply made too.
I don't mind spending more for a quality product that will last a long time and wanted to get some info and see if anyone was using it.
I've read thru the slime link previously.
Eric your link doesn't go anywhere?
Old Aug 15, 2007 | 03:45 PM
Eric_Rowland
That's wierd. I swear it worked this morning. Let's try again - I just did a search on conticomfortkit - 22 results
Me, I stick with plugs and a compressor. I'm not big on squirting liquids into my tires.
Old Aug 15, 2007 | 04:08 PM
naffets's Avatar
naffets
Thanks Eric!
surfin'02
May 18, 2014 07:55 PM
jtpryan
Tires, Wheels, & Brakes
Apr 19, 2011 06:07 PM
Nuff
12
Jun 15, 2007 10:51 AM
Silver JCW Rocket
May 12, 2006 08:10 PM
los_blankeys
Apr 4, 2005 10:00 AM
