R56 100 Octane
Old Aug 14, 2007 | 03:38 PM
1825vine's Avatar
1825vine
100 Octane
I found a gas station by my house that carry 100 octane fuel. What's you guys opinion on that? Will 100 octane fuel be good for our R56? Thanks
Old Aug 14, 2007 | 03:44 PM
tomah's Avatar
tomah
100 octane will only aide you, if your car is tuned to run on 100 octane. putting 100 octane in your car just to do it will not help much
Old Aug 14, 2007 | 03:58 PM
elmalloc's Avatar
elmalloc
so what he's saying is tune your car
Old Aug 14, 2007 | 04:05 PM
70spop's Avatar
70spop
If your car is running fine and not pinging, then there's no need to use 100 octane. Just throwing your money away.
Old Aug 14, 2007 | 04:06 PM
70spop's Avatar
70spop
Crank up the ignition advance!
Old Aug 14, 2007 | 04:37 PM
Loui's Avatar
Loui
Give us a picture of their sign!
Old Aug 14, 2007 | 05:01 PM
SPDinNY's Avatar
SPDinNY
one by us carries 104 octane, whats the big deal?
Old Aug 14, 2007 | 07:54 PM
mufflethis's Avatar
mufflethis
How much ethanol is in it? Keep in mind that ethanol is corrosive to engine parts.
Old Aug 14, 2007 | 08:38 PM
mikeg4572's Avatar
mikeg4572
Try it. It definately makes a difference in the R56. I usually mix it about 50/50 with 91 since thats all we have here. I don't care what people say, it makes a big difference in the R56. I had an R53 before and did not notice any difference. Maybe it has something to do with the ECU allowing more timing and boost with the turbo.
Old Aug 14, 2007 | 09:56 PM
1825vine's Avatar
1825vine
It's the 76 gas station that carry this 100 octane fuel. I think I am going to mix it 50/50 like you. I was told that they are good for Euroupean sports car. Thanks guys.
Old Aug 14, 2007 | 10:02 PM
littlehandegan's Avatar
littlehandegan
Coordinator :: Low Country MINIs
Damn lucky...thats like race gas...correct me if im wrong...i probaly am
Jack
Old Aug 14, 2007 | 11:27 PM
bluesmini's Avatar
bluesmini
I use 100 for track days now. I'm not on my third engine and don't want to get a fourth. I do dirty dirty things to my engine for long periods of time. If you do also you need to be running 100. It's not for the performance but for its ability to not allow premature detonation. That makes pistons and rings break. Trust me on this one.
Old Aug 14, 2007 | 11:38 PM
not-so-rednwhitecooper
It depends wether or not its leaded or unleaded.
I wouldnt suggest using leaded gas in any car newer than 1981. Leaded gas such as Cam2 (109, 112 and 114) will mess up O2 sensors and Cats.
Unleaded high octane (over 94) will help out in high compression cars, or cars that use a forced induction power adder.
I run 100 octane TurboBlue in my GTO and the Impulse. It gives me piece of mind when I crank up the boost past 20 or 25 psi on the Impulse knowing that I dont have to worry about detonation because of bad fuel.
Old Aug 14, 2007 | 11:44 PM
ScottRiqui's Avatar
ScottRiqui
The "leaded versus unleaded" is a good point. There's a station in Virginia Beach that has 100-octane and 110-octane for the same price, but the catch is that the 110-octane is leaded, and isn't legal for street use.
I think the 110-octane leaded at that station is illegal for street use even if you have an older car without a catalytic converter - it has something to do with the fact that the price doesn't include the taxes that are added for gas that's going to be used on public streets.)
Old Aug 14, 2007 | 11:48 PM
Tüls's Avatar
Tüls
Turbius Maximus
running 100 octane creates a knock free enviroment for the most part... no knock no pull in timing.. no pull in timing... you get ALL the power she can make... plus she'll just run better...
Old Aug 15, 2007 | 04:24 AM
rosmakloma's Avatar
rosmakloma
I have a hard enough time finding stations with at least 92 octane.
Old Aug 15, 2007 | 06:54 AM
PaulCIssa's Avatar
PaulCIssa
We have one station in my area that sells CAM2. You can't get in the place on a friday night. Race trailers and rods line the side of the highway for a 1/4 mile.
Old Aug 15, 2007 | 12:30 PM
The way to get around the legality of running leaded race gas in a street car is to dispense it into a container before putting it into a vehicle.
The gas stations that sell CAM2 here will not allow the gas to be pumped directly into a vehicle, and they have a larger spout on the nozzle to prevent it.
Old Aug 15, 2007 | 12:34 PM
mozzarella's Avatar
mozzarella
Leaded gas will take care of your cat.
Old Aug 15, 2007 | 05:14 PM
Klasse Act's Avatar
Klasse Act
Its only good if you infact need it due to ignition timing and/or boost and make sure of this, THAT IT'S UNLEADED RACE FUEL!
Old Aug 15, 2007 | 08:16 PM
Tüls's Avatar
Tüls
Turbius Maximus
ha ha yeah good point... typically 104 and lower are unleaded.. but you should still check
Old Aug 15, 2007 | 09:15 PM
Your guy's cars came with cats? Hm, mine must have fell off on the way home from the dealer.
:p
Old Aug 15, 2007 | 09:52 PM
Brakefade's Avatar
Brakefade
If you're gonna be on a track during a hot summer day, doing lap after lap after lap, 100 octane will be a lot safer for your engine than running 91-93 octane. Plus you get a small increase in performance.
Here's a list of 76 gas stations that sell 100 octane gas.
ian260
Mar 29, 2017 06:08 AM
minimofo
Dec 26, 2015 12:03 PM
pkillur
Tires, Wheels, & Brakes
Oct 1, 2015 03:59 AM
gnhovis
Sep 28, 2015 04:07 AM
