Suspension adjusting rear track?
Old Aug 10, 2007 | 05:32 PM
Rally@StanceDesign's Avatar
Rally@StanceDesign
If someone has installed 2 sets of adjustable control arms in the rear of their car, it is my understanding that by shortening the control arms and shifting the rear mouting points of the trailing arm you are able to narrow the rear track.
Anyone know how much room for adjustment is there? Are there things that could possibly get in the way or possibly cause rubbing on wider wheels etc?
Old Aug 10, 2007 | 05:44 PM
Beecher's Avatar
Beecher
yeah, there isnt much clearance between the tire and the trailing arm. If you ran a big rim like a 18, with relativly narrow tire, like a 205, or maybe even a 215, you should be able to do it. Not entirely sure why you want to do it tho? An alternative to getting spacers the get wider track in the front than in the back? Just curious
hope that helped
Beecher
Old Aug 10, 2007 | 05:47 PM
Rally@StanceDesign
hope that helped
Beecher
Just trying to fit some wide 15's in the rear and have been getting some rubbing on the outside. If i could adjust the track ever so slightly to bring them inwards, that would be amazing.
Old Aug 10, 2007 | 05:50 PM
lhoboy's Avatar
lhoboy
Sounds like you need to use a wheel with a different offset.
Old Aug 10, 2007 | 07:52 PM
Rally@StanceDesign
nah I'm totally fine with the offsets of my wheels...they are perfect where they are. Exactly how i wanted them.. I just made this thread to find out about the adjustment capabilities of the rear track of our cars. Thanks though.
Old Aug 10, 2007 | 09:36 PM
70spop's Avatar
70spop
I would think that you'd be able to get 'em in about 1/8" to 1/4" at least, but I'm not sure if that would place undue stress on the bushing at the front of the trailing arm. You might also induce some weird alignment issues, although with two adjustable control arms (per side), it's possible you could adjust the toe correctly. However, doing so *might* also be at odds with getting the wheels in.
I'm guessing. I haven't torn apart the rear suspension to see how it all fits and works; I just know the basics.
Old Aug 10, 2007 | 10:40 PM
onasled's Avatar
onasled
If you have both upper and lower adjustable arms, then yes, you should be able to narrow the track with no problems at all. You might get as much as 1/2" in on each side wih the trailing arm bushing carrier.
Also just try tweekin the arms. You can use the top or the bottom to adjust both toe and camber.
Old Aug 11, 2007 | 05:18 AM
Rally@StanceDesign
Thanks so much onasled.....that's the info i was looking for
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
ebowling
90
Aug 4, 2019 09:15 AM
Minibeagle
Aug 13, 2015 10:00 AM
OutMotoring
Aug 6, 2015 09:32 AM
