Navigation & Audio Speaker sizes for the R56 w/Hi-Fi upgrade
Old Aug 8, 2007 | 07:18 AM
Loony2N's Avatar
Loony2N
I've searched, but didn't find, a post stating the sizes of the OEM speakers for the HIFI Upgrade in the R56. Can someone tell me the size for each location? Thanks!
Old Aug 8, 2007 | 07:29 AM
symphosomatic's Avatar
symphosomatic
Here's something from another NAMer.
Take care,
Adam
Attached Thumbnails Speaker sizes for the R56 w/Hi-Fi upgrade-speaker_sheet.jpg
Old Aug 8, 2007 | 11:45 AM
Robin Casady's Avatar
Robin Casady
I believe the speaker sizes are the same for the standard and HIFI. The HIFI just adds tweeters. I can verify that the rear are 6x9s in the HIFI. I just removed them. There is a separate tweeter mounted in front of each 6x9.
I'll be replacing the rears with Infinity Kappa 693.7i 6x9s.
Old Aug 8, 2007 | 11:48 AM
Loony2N's Avatar
Loony2N
Thanks, but I'd like to know for sure. Yeah, I can see the rears are coaxial.
Old Aug 8, 2007 | 12:05 PM
Robin Casady
You could PM dneal. He seems to have done a fair amount of delving into the HIFI system.
I can't imagine BMW making different size cutouts in the door panels for the HIFI speakers. That just doesn't jibe with their cost-cutting concerns on the R56.
Old Aug 8, 2007 | 07:05 PM
DyeLooper's Avatar
DyeLooper
Fine choice if I say so!!
Old Aug 8, 2007 | 07:34 PM
Robin Casady
You may have been the influencing force that got me to look at the Kappas. Although a Kappa in Japanese folklore is a mischievous water sprite known to eat children, but prefers cucumbers.
The choice was down to Focals or Kappas. The Kappas come with two external crossovers, and thus have two sets of connectors -- one for the tweeter, and one for the woofer and mid-range speakers. The 6x9 wiring in the HIFI has a pair of wires for the 6x9 and a pair for the tweeter. Presumably, there is a crossover in the amp. So, I figure I can just connect directly to the Kappas dual inputs without using their external crossovers.
Old Aug 15, 2007 | 03:40 PM
jascooper's Avatar
jascooper
I was considering doing this. Please post when you make the switch and what issues you run into. Although the HIFI sounds pretty good as it is.
Old Aug 15, 2007 | 11:39 PM
Robin Casady
The speaker swap is just part of a rear area conversion project. I'm removing the rear seats, building a wall up to the window line to form a barrier between the cargo area and passenger area (front seats). The wall will hold an MDF speaker box for the two 6x9s. The rear will get a visual cover to conceal the cargo area. So, the original position of the 6x9s would be muffled.
I won't be able to tell you about fit issues, if there are any, but I will report any electrical issues.
Old Aug 16, 2007 | 06:04 PM
MotorMouth's Avatar
MotorMouth
something like this?
Old Aug 16, 2007 | 06:41 PM
DyeLooper's Avatar
DyeLooper
Where's the Pick dude?
Old Aug 16, 2007 | 07:17 PM
MotorMouth's Avatar
MotorMouth
the pic that is right above your 's?
Not sure why you don't see it. I see it in both my post and your quote of me.. They are hosted on imageshack.
Or am I just being dumb and missed what you meant?
Old Aug 16, 2007 | 08:43 PM
DyeLooper's Avatar
DyeLooper
Sorry, wasnt on the computer I was at!
Old Aug 16, 2007 | 08:46 PM
DyeLooper's Avatar
DyeLooper
SWEET!!!
Old Aug 16, 2007 | 11:54 PM
Robin Casady
Wow, those are big tweeters!
Old Aug 17, 2007 | 12:11 AM
MotorMouth's Avatar
MotorMouth
*!SPEW!* that just made pepsi get on my keyboard!
I found that hilarious for some reason.
Old Aug 25, 2007 | 11:37 AM
JollyRodger's Avatar
JollyRodger
Anyone who actually drives that with those running will have brain damage inside a year....looks cool..but very impractical
Old Aug 26, 2007 | 11:48 AM
Birdman's Avatar
Birdman
WOW!!!
Anyone want to come to Long Island and remove my rear seats, dynamat the back end, and install a small speaker wall (just put in the 2 6x9's or replace with round 6"'s) and add a nice 10" subwoofer and amp? I'll pay for all parts and buy the beer and pizza!!
Common, you know you want to!!!!!
Old Aug 26, 2007 | 12:50 PM
jascooper's Avatar
jascooper
Anyone who plans to drive that car already has brain damage...
Maybe they're planning to have kids and wanted to see what it would be like.
Seriously, though, I've seen an installation where a nominal sized sub (maybe 10") was installed in the well inside the boot. Looks like it would be worth doing. Anybody done something like that with the HIFI upgrade. Can someone point me to where it would get hooked up (where to connect a crossover, etc.). I know there's an amp back there for the upgrade, so it seems like it should be easy, but I'm an electrical idiot. Robin, are U there?
Old Aug 26, 2007 | 02:44 PM
Robin Casady
Originally Posted by Birdman
WOW!!!
I'll do it for the pizza, but I charge $100,000 to come to the East Coast.
Old Aug 26, 2007 | 02:51 PM
Robin Casady
I know very little about audio electronics. I'm just swapping speakers. The majority of what I'm doing is sound insulation. There have been posts about people adding amps and subwoofers. So, you should be able to find others who can advise you. My only comment would be that if you remove the rear seats and put in a floor, there would be a hollow area below it that would be good for one or two subwoofers.
Old Aug 26, 2007 | 08:01 PM
dlroto's Avatar
dlroto
Great dynamat job, that stuff is a real mess to work with but well worth it.
Old Aug 27, 2007 | 06:24 AM
a96bimmerm3's Avatar
a96bimmerm3
I hope you used a heat gun... my experience with that stuff has been not so great if you don't use a heat gun and prep the surface properly. Then again I live in south florida where the temperatures are RIDICULOUS, the stuff tends to peel off easier. The heat gunned on parts of my car are not coming off. We also have used map gas torches to put it on customers cars, works real nice and quick.
marendt428
Nov 14, 2015 10:03 AM
jnrjr79
Navigation/Audio
18
Sep 18, 2015 05:51 AM
marendt428
Aug 8, 2015 04:44 AM
