Suspension M7 USS or H-Sport Comp Rear swaybar
Old Aug 3, 2007 | 08:19 PM
thebillsman's Avatar
thebillsman
Hey, ive been looking for my next upgrade and im torn between spending $250 for the H-Sport Comp Rear Swaybar or $350 for the M7 Under-Strut System. I've only heard good things about both products but which will make a more significant difference in handling and cornering. What advatnages does one have over the other, all opinions welcome.
thanks in advance
Old Aug 3, 2007 | 08:21 PM
PGT's Avatar
PGT
you are on stock sway now? definitely do a swaybar, though the comp might be a bit much unless you are tracking it (even then, some like TSW don't recommend it). The normal 19mm bar is a better choice if you want a more forgiving approach to the limit.
Old Aug 4, 2007 | 12:24 AM
UKSUV's Avatar
UKSUV
or you can get the Comp SET for $300 shipped on ebay....possibly $280
Old Aug 4, 2007 | 05:36 AM
minimarks's Avatar
minimarks
Swaybar will make more of a diff.. USS stiffens the chassis and the swaybar will make the car turn flatter and take out understeer. I personally pefer a 19mm....
Old Aug 4, 2007 | 06:21 AM
hornguys's Avatar
hornguys
Choose swaybar for the most immediately obvious improvement in handling.
Nothing else come close for that kind of money.
Old Aug 4, 2007 | 06:39 AM
PlayPlay's Avatar
PlayPlay
Try:
http://www.helix13.com/mini/products/suspension-chasis
Old Aug 4, 2007 | 11:33 AM
thebillsman
theres a few local events every now and then, i was planning on setting the softest 22mm.. why the 19 over the 22?
Old Aug 4, 2007 | 12:28 PM
minimarks's Avatar
minimarks
The 19 is a better all around bar for people who track the car now and then.. Firmer than that even on the softest setting can make the car a little rough and jittery for daily driving, my 2 cents. And others such as TSW, Dinan, etc like the 19 even for comp. and some suggest if you want to take out more understeer than the 19 will provide to go with camber plates, for a better balanced car...IE: not trying to solve everything with one thing... Just my opinion as I know others will disagree..
Old Aug 4, 2007 | 03:49 PM
UKSUV's Avatar
UKSUV
Originally Posted by pl4ypl4y
Helix is NOT cheaper..ebay....$280 for BOTH FRONT and REAR bars! New in box dropped shipped from H-Sport.
emulajavi
Dec 24, 2018 09:15 AM
wkp1219
Nov 13, 2015 07:52 AM
Etrain
11
Aug 20, 2015 10:22 AM
tag1260
Aug 5, 2015 04:27 AM
