R56 Interior Chrome trim How to?
Old Aug 1, 2007 | 09:24 AM
kevinminict's Avatar
kevinminict
I have the standared grey trim in my MCS. ( trim around the speedo-air vents etc) I want to get the chrome trim pieces and was wondering if anyone has an idea on how they go on. Will I have to take off the grey trim first then add the chrome or put the chrome ontop of the grey?
Just curious before I go and buy it.
Old Aug 1, 2007 | 09:37 AM
CR&PW&JB's Avatar
CR&PW&JB
Kevin, the answer is "yes".
Okay, translation: You can get either the pieces that replace the plastic trim (high $), or you can get plastic chromed covers that you simply pull off the adhesive backing and stick right over your OEM plastic trim.
Depends on how much money you want to spend and if you're willing to sacrifice a little quality.
Old Aug 1, 2007 | 09:41 AM
aem421's Avatar
aem421
If you're going to replace all the grey pieces with chrome, then you're going to have to take all the grey pieces off first and then replace them with the chrome ones. I know on my last car I had the service manual on CD. It was awesome. It basically showed you how to replace every part on the car. If you had one of those it would be easy. Without it, you'll have to search and see if anyone else has done it. If not, it's trial and error. Good luck.
Old Aug 1, 2007 | 09:47 AM
LeonD's Avatar
LeonD
Vendor ad for Outmotoring is selling leather trim rings and they are saying that you simply pull up on the existing rings and they will come off to be replaced by the new ones. Good luck.
Old Aug 1, 2007 | 10:04 AM
kevinminict
OK cool thanks guys.
So the OEM that you get from MINI is alot of $$$ and the grey pieces have to be taken off right?
Old Aug 1, 2007 | 10:06 AM
aem421's Avatar
aem421
Right.
Old Aug 1, 2007 | 10:13 AM
davavd's Avatar
davavd
Somewhere, I can't find it now, I found instructions for removing & replacing the speedometer trim ring. It was pretty involved. I'll post it when I can locate it. I figured the guy sold me the chrome ring because he didn't feel like going to that much trouble.
Old Aug 1, 2007 | 10:26 AM
davavd's Avatar
davavd
Here it is
http://www.mini2.com/forum/interior-...=20#post869970
Old Aug 1, 2007 | 12:57 PM
Hattat's Avatar
Hattat
It`s very hard to change those parts. First of all you should take these in to consideration:
-Nothing goes over the existing silver rings
-Chrome rings don`t replace silver rings
-You have to remove every single part with the silver rings and install new parts with chrome rings.
-Only can holders` rings replace without removing any part.
-Tachometer housing and shift lever housing do not come with chrome rings inside the interior chrome line retrofit kit. You have to buy the complete tachometer and shift lever housing.
I`ve done the replacement by my self. The total procedure was horrible. I`m really capable of mechanical installations but this is out of the way!
If you really want it, talk to your dealer if they can remove those interior trims as careful as an owner.
By the way, the most tricky part is the center speedometer housing. I`ve send the instructions to a thread but I can`t remember which one.
Old Aug 1, 2007 | 01:39 PM
CR&PW&JB's Avatar
CR&PW&JB
Are you trying to say you can't get interior chrome pieces that just fit over the existing plastic trim ?
Just clarifying.
Old Aug 1, 2007 | 02:22 PM
kevinminict
Ohhhh well.
I'll have to stick with the origional trim then. I got the car off the showroom floor. So I cant be too pickey. I guess I'll keep it as it is. Thanks for all your info and help guys! -maybe thell be an aftermarket stuff for it soon bc the r56 just came out.
Old Aug 1, 2007 | 10:35 PM
Hattat's Avatar
Hattat
Just clarifying.
Yes
Old Aug 1, 2007 | 10:48 PM
Hattat's Avatar
Hattat
Forget how to install these chrome bits, you`ll have to remove all these pieces to install the new parts with chrome:
-Door trim panels
-Dashboard trim panel, top
-Center console cover
-Passenger knee protector
-Storage compartment
-Piano Black-in my car- trims
-Air outlet grill/cover right and left
-A column covers
These are the main parts and there are several minor parts as well.
Old Aug 2, 2007 | 03:07 AM
CR&PW&JB's Avatar
CR&PW&JB
Yes
Okay, you have to spoon feed me, here.
Have the aftermarket vendors not developed yet for the R56 ?
And I didn't realize the trim rings changed in the R56 from previous generations.
patsum
26
May 29, 2021 06:29 PM
Norton70
Feb 2, 2017 01:06 PM
molala
Oct 2, 2015 01:53 PM
tag1260
Sep 2, 2015 07:42 PM
