Navigation & Audio Simple auto audio docking solution?
Old Jul 30, 2007 | 09:01 AM
TheBigNewt's Avatar
TheBigNewt
Is there a simple wire to just connect the docking port to the Mini Aux in for an iPod? I don't want a cradle/charger unit, just a wire to improve the sound from the iPod beyond the male/male wire.
Old Jul 30, 2007 | 09:47 AM
maximoose's Avatar
maximoose
Ipod to Aux
Ipod Dock Conn To 3.5MM Cable
I got it from Amazon
Old Jul 30, 2007 | 10:56 AM
Robin Casady's Avatar
Robin Casady
How does it sound? If I turn the preamp off in the Griffin TuneFlex dock, the volume is very weak. Running a male-to-male cord from the earphone jack on a 60GB iPod to the AUX seems to work better than from the dock connector without amplification. However, it sounds better through the dock with the preamp on.
I wonder if getting a quality preamp and using the cable above would be feasible?
Old Jul 30, 2007 | 11:04 AM
TheBigNewt's Avatar
TheBigNewt
Maximoose: Thanks, that's what I want. It can't be much and it could sound better even without amplification .
Old Jul 30, 2007 | 11:26 AM
Robin Casady
Also try the earphone to AUX cord. They are available at Radio Schlock, cheap. Or, like this on ebay.
Old Jul 30, 2007 | 12:26 PM
maximoose's Avatar
maximoose
$10, can't go wrong. On the plus side your HU controls the volume level of it, so just setup your playlist and hit play. The sound quality is alot better, although I recommend tweaking it on both ipod and HU
Old Jul 30, 2007 | 02:03 PM
TheBigNewt's Avatar
TheBigNewt
That's what I use now. I was hoping for better sound from the line out dock connector. I didn't realize that the Belkin unit and others use a preamp though.
Old Jul 30, 2007 | 02:53 PM
Robin Casady
I'd stay away from the Belkin one. The Griffin TuneFlex AUX Flexible Charging Cradle is good. Available at the Apple Store online.
One of the major benefits to the cradle, besides the preamp, is that it charges the iPod while you drive. It does have disadvantages. It takes up the cigarette outlet; you can't put it where you want; and the flexible arm sags under the weight of a 60GB iPod. A little Velcro fixed that for me.
Still, I may someday go for the iPod Integration, in spite of the price, so I can control it from the steering wheel, and see playlist on the NAV.
Old Jul 30, 2007 | 04:04 PM
jyarrow's Avatar
jyarrow
I have a cable like this and think that it's great. It works much better than using the headphone jack. Sounds better. Mine has a device in the middle that allows the cable to complete retract into it so there's not a lot of extra cable running around.
I just let the ipod sit underneath the E brake. I might get a mount sometime, but I tend to listen to longer playlists and podcasts so it works great for me.
I don't feel the need to charge the ipod in the car. The battery life is long and I sync with the computer everyday and use it on portable speakers that charge it.
Old Jul 30, 2007 | 05:14 PM
TheBigNewt's Avatar
TheBigNewt
What brand is the one with the retractor that you have? I don't care about charging either. Mine plays for 16-20 hours, that's plenty for me.
Old Jul 30, 2007 | 06:26 PM
Robin Casady
Probably something like this.
Old Aug 10, 2007 | 09:23 AM
kimmc's Avatar
kimmc
I had one of the basic iPod docks hanging around the house, so I use it in the mini. It acutally sits right in the ashtray (with the lid up) perfectly, and doesn't slide around at all. I got a charge cord that I plug into the cig lighter whenever I need a charge, and take it out when it's done.
It's not a perfect solution, but I think it sounds better than coming right out of the headphone jack.
Attached Thumbnails Simple auto audio docking solution?-215qwzfsngl._aa280_.jpg
Filmy
15
Jun 6, 2023 06:27 AM
iclancy82
Jan 2, 2021 08:59 PM
minimofo
Sep 30, 2015 12:26 AM
Accessory Products
Sep 9, 2015 10:29 AM
Filmy
Sep 7, 2015 08:27 PM
