Suspension Camber optical illusion?
Old Jul 18, 2007 | 01:03 AM
ScottRiqui's Avatar
ScottRiqui
Why is it that even though I have more negative camber in the front than in the rear, the rear wheels look like they're tilted so much more?
If I'm understanding correctly, the camber angle is just the angle between the vertical axis of the wheel and an invisible line perpendicular to the ground, regardless of whether it's the front or rear wheels being measured.
I'll have to double-check the specs from my last alignment, but I think I have about -1.6 degrees in the rear, and -2.3 degrees in the front, but the front wheels *look* like they're almost vertical, while the rear wheels look like something off of a 1970's baja bug!
Is it just an optical illusion, or is there something different about how camber is measured depending on whether it's a front or a rear wheel?
Old Jul 18, 2007 | 03:24 AM
LannyMCS's Avatar
LannyMCS
That certainly looks to be a lot more than -1.6 camber in the rear.....but they are measured in the same fashion.
Old Jul 18, 2007 | 03:54 AM
snid's Avatar
snid
Are there front camber plates on the car? If not, you do not have -2.3° of camber in the front. Probably -0.23°.
Old Jul 18, 2007 | 06:00 AM
ScottRiqui's Avatar
ScottRiqui
Yes, camber plates in the front and adjustable lower control arms in the back.
Old Jul 18, 2007 | 06:09 AM
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
Looking at this photo and the other you posted on "lowered cars" thread, I'd say your rears *do* have way more camber than the fronts. You are pretty slammed, especially in the rear. Of all the possibilities, which include an optical illusion, others could be that your alignment guy lied to you (it's possible) or you have the numbers reversed.
btw, the question about camber plates is relevant. Without front camber plates you cannot achieve anything like -2.3deg. Also without adjustable control arms in the rear, you cannot get them as upright as -1.6 with the slam you have.
OK, ignore the last sentence...
Dont know what to tell you now! btw, what suspension allows you to get so low? Is there still travel in the shocks?
Old Jul 18, 2007 | 06:28 AM
ScottRiqui's Avatar
ScottRiqui
They're the JIC/Cross coilovers. Both the front and rear are height-adjustable without having to adjust preload, so I still have full suspension travel at all four corners.
Perhaps I shouldn't have used my own car for this thread, since mine is an extreme example. But even on bone-stock cars, the rears always seem canted in more than the front, and I thought even the factory settings had a little more negative camber in the fronts.
Old Jul 18, 2007 | 07:10 AM
ScottinBend's Avatar
ScottinBend
Stock camber for the MINI is more at the rear than fronts.
Old Jul 18, 2007 | 07:14 AM
cristo's Avatar
cristo
Alliance Member
factory setting is about 0.5 degrees negative camber in front, and 1.5 degrees
negative camber in the rear.
Old Jul 18, 2007 | 07:20 AM
BBCooper's Avatar
BBCooper
My two cents
First off to prove to yourself the front & rear are different use a carpenter's square.. Set one edge on the ground with the other edge creating that vertical reference line.. Then you can use your fingers (or a ruler if you want to get high tech) and check the distance to the top of the rim to the vertical edge.. The bigger the gap from the vertical edge the more negative camber on that wheel..
Second I think there is optical tricks happening here.. the front wheels have a higher arch then the back (espically on your picture above). With the rear arch so close to the tire.. one has the guess the tire is more pushed in..
Either way, that *looks* great.. and if it corners great too... Then it is perfect..
Just my 2 cents
Old Jul 18, 2007 | 07:23 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
For Stock MINIs the rear camber is more negative yes.
Front is about -0.5 and rear about -1.0 to -1.5
For your MINI with coilovers and aggressive alignment,
Your settings are probably corrent but there is an optical illusion happening.
First your alignment is done with weight in the front seat or seats to simulate the load so the reading is done under load and if there are no persons in your car at the time of the photograph then that is missing.
Second, the position of the wheels in each wheel well is different front to rear. Ride height can be different or not, you can measure it using the top of the wheel arch as a guide comparing front to rear.
Each wheel has it's position in the wheel well relative to the hub and I find that the rear wheel sits slightly closer to the outer edge while the front wheel lies slightly inside relative to the fender and arch so clearance is a little tight in the rear with a lowering MINI.
I have coilovers and similar camber settings on my MINI and it looks like I don't have the -2.4 degrees in the front I ordered. It's there, look at your inner front tire treadwear. If with heavy cornering you use the tires evenly on the fronts then you have lots of front camber. If you wear out the outer front edges rapidly then you probably don't have that much camber.
Old Jul 18, 2007 | 06:50 PM
90STX's Avatar
90STX
One more option, though probably unlikely. I had an early set of adjustable rear control arms, and the jamb nuts on the turnbuckle adjustment wouldn't stay tight. Over time, they would adjust themselves resulting in dramatically more rear camber. It was pretty spooky, as one of the tires got enough negative camber to make contact with the inner fender liner and rub a hole through it. I don't want to think about how much camber that was.
Scott
90SM
Keet
Suspension
Aug 30, 2016 03:46 PM
conky
Apr 6, 2016 08:03 PM
fkrowland
Sep 30, 2015 10:30 AM
Keet
SCCA Solo and ProSolo
Sep 20, 2015 01:02 PM
Keet
Sep 19, 2015 09:45 PM
