Suspension New Megan Suspension
Old Jun 18, 2007 | 11:45 AM
tsprayfhs's Avatar
tsprayfhs
My new suspension from Megan Racing just arrived. Pepper has just rolled over 90k miles and the shocks are getting tired. I’ve been waiting and planning this move for over 18 months. After a lot of looking and listening, I decided to go with Megan Racing. I got Adjustable camber plates, shocks with adjustable valve settings, new springs with adjustable ride height and suspension travel, all for just over a grand; who could ask for more. Add to that camber and toe-in links for the rear. All-in-all this should keep me busy tweaking, adjusting and just plan fiddling at the track for some time.
The parts were well packaged and arrived in perfect condition. The finish on the parts was of surprisingly high quality. If the fit and performance are on par with their appearance, I’ll have the ride of my life. Dealing with Megan Racing has been great. Most of the time, I dealt with Steve. He is an invaluable resource on MINI suspension, and to deal with me he must be one of the most patient persons on the face of our planet.
I hope to get the parts on tomorrow. I will be going to a friend’s house for the install
I’ll keep you informed on how the install goes as well as their performance.
Motor on
Old Jun 18, 2007 | 12:41 PM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
That sounds great. Hope the install goes well. Post some pics if you can we always like those.
Old Jun 18, 2007 | 01:58 PM
sprp85's Avatar
sprp85
let us know
i'm waiting to install those very soon too
oh and PM went..
Old Jun 18, 2007 | 02:27 PM
hemiheaded18's Avatar
hemiheaded18
Thats prolly about 300-500 bucks less than all of that stuff seperately. Let us know how the install goes and well it feels.
Is this what you bought? It seems to have everything you listed minus the rear adjusters.
http://www.meganracing.com/products/...d=459&catid=93
Old Jun 18, 2007 | 06:00 PM
Mugami's Avatar
Mugami
Coordinator :: River City Minis
The Megans are good for street use. You should go to a slightly heavier spring combo if you plan on racing.
Old Jun 19, 2007 | 08:15 AM
tsprayfhs's Avatar
tsprayfhs
Yes I recieved everything from Megan Racing. You link is good. When I said a little over a grand that did not include the rear links. The links are available from Megan. More to the point not all of their MINI products are always listed. Give them a call ask for Steve and tell them you talked with me.
Oh I guess I forgot to say I am Tom Spray. You might know me from the Dragon or Phil Wicks track days. I am a classroom and on track instructor since '03. I'm hard to miss ... big beard and poneytail.
I don't race the car but I do Track it alot.
Motor on
Old Jun 19, 2007 | 03:18 PM
Mugami's Avatar
Mugami
Motor on
kk.. good to hear. With the springs that come with the shocks 8kg/6kg. I had to go to 12 turns (full turns of the adjuster nut) of the preload adjustment to keep them from bottoming out on medium speed sweepers used in Autox.
What I went to is custom springs about equal to 8.7kg in front and 6.5 in the rear. This is because im not a fan of having to Preload a suspension. Hope this helps if you havent had time to try them out yet.
Old Jun 20, 2007 | 05:24 AM
meb's Avatar
meb
...you shouldn't have to preload these. Just tighten the lower spring perch enough to keep the spring from becoming unseated. But, before this, make sure that the cylinder is screwed all the down into the sleeve. The damper will have all the travel it can have if installed this way.
If your front springs are 469# from Megan, they should be 7" long...the 6" springs do not have enough travel. If you have 6" springs I understand your problem. These will not work. You can call either Megan or Eibach for new springs - a great source for Eibach springs is Ground Control. They also have Eibachs spring sizing chart as a link. Ground Control also have a slightly barrel shaped spring designed for adjustable coilovers. This spring type will give you - if I remember - an additional 1/2" in spring travel than a standard linear rate spring.
Old Jun 20, 2007 | 08:13 AM
Mugami's Avatar
Mugami
Thanks meb. On the ones i did.. after wieghing the car. I went to Thurston Spring company and had custom ones made to my specs. With the expectation of 1.1G load and 3" of travel. They seem to do the Job for my Driving style. Ride is good, Im using 98% of the travel during Autox days and the car is very Neutral.
Old Jun 20, 2007 | 09:08 AM
tsprayfhs's Avatar
tsprayfhs
Gee I'm confussed! I don't have any problem with the Megans. In fact they have surpased my expectations to this point. True I have not tracked them .. yet. That will be dealt with at Talladega next month. They ride great with not bottoming out. Megan sure seems to have it correct.
Motor on
Old Jun 20, 2007 | 11:57 AM
meb's Avatar
meb
I think, as Mugami wrote, track exposure revealed a weakness. I also had some problems on the road, but the new spring length and bumpstop was a fix.
Old Jun 21, 2007 | 11:48 AM
tsprayfhs's Avatar
tsprayfhs
These came with the new interation of springs, valves, bump stop and settings. An so far om the street they are great.
Motor on
Old Jun 22, 2007 | 02:00 PM
tsprayfhs's Avatar
tsprayfhs
Today I set the valving to one or full soft. t rode quite well and handled fine. I was suprised. Wow I am impressed. I put on about 50 miles half in city traffic and the rest on mountian twisties.
Motor on
Old Jun 23, 2007 | 12:53 AM
Mugami's Avatar
Mugami
Glad you like them. Oh and mine did come with the 469 springs.
Old Jul 3, 2007 | 02:58 PM
Rally@StanceDesign's Avatar
Rally@StanceDesign
Motor on
They have changed the valves too?
Old Jul 4, 2007 | 01:14 PM
tsprayfhs's Avatar
tsprayfhs
I may have miss-stated about the valving. After the holidays i'll get this cleared up. Sorry IF I misled anyone. I did have an unusual incident yesterday. I came accross some highway construction, with speed bumps. I was doing around 40MPH when I hit them. I had a brief rub on the front left tire, I have never rubbed in the front, there just isn't that much travel in the stock setup. The Megan's have not been touched, (I left them as shipped) No I have not found the rub spot, but I did heard. I am looking forward to playing with the settings.
Motor on
RIchard Nguyen
Sep 14, 2016 11:43 AM
vulkandino
Oct 31, 2015 08:29 PM
CooperSharp
Oct 12, 2015 09:21 AM
Tires, Wheels & Brakes
Oct 1, 2015 10:38 AM
Oct 1, 2015 10:17 AM
